| diyAudio Sponsor | ||
#11 |
G,
Can you describe your PSU especially in terms of filtering? I breadboarded a se el84 with no hum but have since built the final version but--guess what--hum! It's weird, it hums sometimes and at other times not. I can tightly grasp a signal input lead and get more hum?? I thought it was the tube proximity to the transformer but looking at your rig I don't think so. Anyway, great job and I am excited for you. Rick BTW, I enjoyed listening to my breadboard so much that I may just go back to it for a while. |
#12 | |
diyAudio Senior Member
Frank |
#13 |
Hi Frag,
The power supply is essentially a Zen power supply. For some reason I can't pull up the Zen site so I can't leave a link. The supply uses two 32 uF dual section caps and two 3.3uF metalized poly caps. The cool thing is that the decware site has a pictorial step by step instruction manual for building an older model of their amp. Who am I to look a gift horse in the mouth. I changed the value of a few resistors for the 5687 but I used their layout. When their site is back up I will send the link. G
Gavin |
#14 |
Here is the link to the Decware instructions. It's a nice simple and effective layout.
G http://www.decware.com/zkit01.htm
Gavin |
| finally getting going | Spica | Introductions | 1 | 20th January 2008 02:57 PM |
| Its done finally | trailsnail85 | Car Audio | 0 | 27th August 2004 06:00 PM |
| Finally | jpb200 | Multi-Way | 2 | 26th May 2004 01:58 AM |
| Finally, almost done with first IGC | officeboy | Chip Amps | 3 | 11th February 2004 04:24 PM |
| JE Labs 300b round 5. MUSIC!! MUSIC!! | TubeHound | Tubes / Valves | 14 | 11th January 2003 12:02 AM |
| Page generated in 0.07589 seconds (70.56% PHP - 29.44% MySQL) with 11 queries |
