Tubing Testing...how are these numbers? - diyAudio
Old 7th May 2008, 07:00 AM   #1
whubbard's Avatar
Default Tubing Testing...how are these numbers?
I'm looking to buy a pair of siemen's 7308s, and I've found a good seller who has tested the tubes. Here are the results:
Quote
Tube1 - A1 = 18,0/13,0 A2 = 18,0/13,0
Tube2 - A1 = 18,0/13,0 A2 = 18,0/13,0
Both tubes have A6 9C stamped on small plates inside. If you know how to dechifer the siemens codes please share that information with me.
For a 7308 is this good/bad? It will be used in an preamp.
I can guess by the numbers that these tubes are obviously matched, but is this 18/13 good. (frankly, what does it mean)
Also, I read abou it somewhere else, but I believe A6 means it was the 6th production, I've heard the 4th was the best, but for the price, I think these will be fine.
Thanks,
West
Old 7th May 2008, 08:11 AM   #2
cerrem is offline cerrem  United States
cerrem's Avatar
The only thing that comes to mind is the 18 is 18mA where the test took place..and the 13 is 13mA/V for transconductance...
Chris
Old 7th May 2008, 08:15 AM   #3
whubbard's Avatar
Would you say the tubes are good by that guess? Or is it still hard to tell?
Old 8th May 2008, 01:53 AM   #4
cerrem's Avatar
Yes....that would make the tubes test in the high range...
Chris
Old 8th May 2008, 04:28 AM   #5
whubbard's Avatar
Thank you Chris.
-West
Teflon tubing for jacket material otto88 Parts 15 15th October 2013 01:06 AM
Magnesium tubing jlsem Analogue Source 1 3rd March 2008 02:02 AM
shrink tubing for DIY Speaker Cables billiam Everything Else 3 23rd March 2003 09:04 PM
Re-tubing Quickie M60 (EL34 quads) wheezer Tubes / Valves 10 4th March 2003 01:52 AM
Copyright 1999-2017 diyAudio
