Are my Speakers efficient enough for my Amp? - diyAudio
Old 6th May 2008, 11:47 PM   #1
Default Are my Speakers efficient enough for my Amp?
I have a Lafayette 224A amp that I recently purchased and a pair of Cerwin-Vega L-7 speakers that I bought back in the early '90s.
The amp puts out about 6WPC and my speakers are rated for power handling of 75 watts/8 ohms and sensitivity of 92dB.
Are my speakers efficient enough to be driven effectively by this amp?
Old 6th May 2008, 11:52 PM   #2
Sal Brisindi's Avatar
You should have no problems driving those speakers unless you play ear splitting hard rock....
Sal
Old 7th May 2008, 01:00 AM   #3
tubewade's Avatar
I agree with Sal. 6 watts is 7.8dB so with one 92dB speaker you can achieve about 99dB. You have two of them so add 3dB. You also have two channels of amplifier power so add 3 more dB. You are now at 105dB. SPL falls off by 6dB every time you double distance, 2 metres rather than one metre for example, in free space. You are not in free space, more than likely, you are in an enclosed room. In an average listening room I would expect you to be within 6 or so decibels of 1 metre readings in your listening position. So, you should be able to get close to 100dB SPLs in your seat. That is more than enough for acoustic, unamplified music. If you listen to extreme rock music that is intended to be heard at 100+ dB 6wpc probably wouldn't be sufficient, but I have a feeling that if you were listening to that you wouldn't be asking this question.
Best,
Wade
Old 7th May 2008, 05:55 AM   #4
Thanks for the input guys, i am glad to know these will work well with my amp.
The speakers have been in storage for 6 years now and I am excited to finally be able to use them again.
Most Efficient Speakers ? EdT Multi-Way 6 18th August 2007 11:55 PM
Efficient speakers for 7Wish matthew2456 Multi-Way 13 26th August 2006 02:58 PM
Are my speakers efficient enough for tubes? alexmoose Tubes / Valves 83 19th May 2006 06:31 PM
Efficient DIY speakers for gainclone under or around $300 US? TheDriver41 Multi-Way 25 25th September 2004 04:18 AM
Copyright 1999-2017 diyAudio
