doesn't sound quite right - diyAudio
Old 6th May 2008, 10:39 PM   #1
Default doesn't sound quite right
A friend of mine and I built a 6bq5 amp with 12at7 preamp. Anyhow, after much trial and error, I got it running and it sounds kinda hollow on most of my CD's. Lots of mid not much else really. It doesn't have any tone control type circuitry in it. Now in the process of getting it set up, I accidentally put the 6bq5's in the 12at7 sockets and vice versa. I wasn't sure if this would damage the tubes sufficiently to make it sound worse than expected. I will try to get a scan of the schematic on here tomorrow. I have to scan it when I get home (I'm at work now . Any help would be greatly appreciated. Thx
Old 6th May 2008, 11:23 PM   #2
SY's Avatar
Take DC voltage readings (caution, DEADLY stuff in there!) around the circuit and note it on the schematic. That will greatly help troubleshooting. Especially important are cathode and plate voltages.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 7th May 2008, 01:57 AM   #3
Ty_Bower's Avatar
Photos and a parts list might help, too. Is it single ended? Push pull? What kind of transformers did you use?
Datasheet for JRC2039G - the whole WWW doesn“t know ... Groundloops Parts 10 18th February 2007 09:40 AM
PC doesn't boot Devil_H@ck Everything Else 41 8th June 2005 09:41 PM
Why doesn't this sound dreadful? bigwill Full Range 16 2nd May 2005 05:06 PM
Amp doesn't like computer :/ Bryanm Solid State 1 18th June 2003 11:02 PM
Copyright ©1999-2017 diyAudio
