Is this the dumbest question? - diyAudio
Old 6th May 2008, 02:26 PM   #1
Default Is this the dumbest question?
Hey guys.
Without going into the vagaries or otherwise of the SRPP tube topology, has anyone tried or better still why cant you setup a tube in se config in the abovementioned cofiguration?
Nick
"Better to say nothing and keep them guessing than to speak and remove all doubt."
Old 6th May 2008, 02:46 PM   #2
SRPP is inherently push-pull. It can work with two halves of the primary in the cathodes (no center tap) and the secondary connected to a speaker.
Old 6th May 2008, 04:00 PM   #3
kevinkr's Avatar
It can be done, has been done, efficiency is poor, white CF seems to work better into low Z loads. SRPP works best with known and constant load impedances - consequently speakers aren't an optimum load.
There are a number of SRPP power stage designs out of Japan which you can usually find in cdrom tube amp schematic collections sold on eBay. Googling may turn some up as well.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
do i REALLY need a crossover?? and an amp question. and an ohm question legendaryfrog Multi-Way 4 29th October 2006 01:39 AM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
dumbest question eV4R! Hybrid fourdoor Chip Amps 2 14th September 2003 11:22 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Copyright 1999-2017 diyAudio
