Differential to single ended...
Old 2nd April 2003, 08:18 AM   #21
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi Jay,
Please enlighten me! :-)
Bas
Old 2nd April 2003, 03:05 PM   #22
After having listened for a while...I have to admit...that the sound is no better that the op-amps..maybe even worse...actually ...it is worse.. :-(
Question is why? I suspect the main problem is that the different tubes do not have the same load to work into..as Brett suggested earlier. I connected it as in above schematic..Could this be the main culprit? Would this be solved if I loaded each output stage with 47k resistor and even the same cap.(will do this anyway and see for myself)..but still only take the output from one stage ofcourse.
or
Operating point not optimal? 3mA per tube. b+ is 320vdc so Vp should be around 116vdc.
Would appreciate any input on this...
Differential to single ended...Hide this!Advertise here!
Driving differential ADC with single-ended source suzyj Digital Line Level 9 19th May 2009 08:39 PM
single-ended to differential? gentlevoice Digital Line Level 16 17th December 2008 07:18 AM
testing a single ended or differential topology Stefanoo Pass Labs 11 26th October 2007 06:59 PM
Converting from single ended parafeed to differential dsavitsk Tubes / Valves 9 12th July 2007 07:46 PM
Volume control + Single Ended -> Differential Amp koolscooby Solid State 2 6th April 2004 12:50 AM
Copyright ©1999-2017 diyAudio
