Toroidal output transformers with screen drive- why not? - diyAudio
Old 5th May 2008, 03:26 PM   #1
GordonW is offline GordonW  United States
GordonW's Avatar
Default Toroidal output transformers with screen drive- why not?
Just had an interesting thought.
Toroidal output transformers seem to have one drawback... the problem with very quick magnetic saturation due to primary DC current mismatch between the two sides, using push-pull output tubes.
Well... seems that most screen-drive amps can get away with VERY LOW bias current... to the tune of 3ma to 5ma DC on each tube, for a push-pull pair!
This seems to be an ideal situation for toroidal outputs, it would seem to me. With that little bias current, even large-percentage shifts in bias current would make for very small actual changes in DC current differential between the two sides...
Anyone tried this, or have any ideas as to why this might or might not work?
Thanks!
Gordon.
Speaker Design, Restoration and Repair- since 1985.
Old 5th May 2008, 04:53 PM   #2
JoshK is offline JoshK  Canada
Neat observation. However, who makes reasonable priced toroid OPTs? Plitron's are very expensive IIRC.
Old 5th May 2008, 05:58 PM   #3
alexg is offline alexg  Philippines
alexg's Avatar
Default Re: Toroidal output transformers with screen drive- why not?
I am using a 120VA mains toroidal transformer as a PP OPT for my KT88 amp and I am measuring DC imbalance of 6ma and I am not getting any magnetic saturation on them.
The KT88 are cathode biased and triode strapped, producing around 20 watts per channel. Each power tube has its own cathode resistor and bypass, I previously configured it to have a shared resistor and when I installed individual cathode resistors it seems to be more balanced.
Old 5th May 2008, 09:21 PM   #4
GordonW's Avatar
Default Re: Re: Toroidal output transformers with screen drive- why not?
That's kind of the direction I was going with my thinking, when starting this discussion.
The lower impedance ratios of power transformers could be just what is needed for a PPP screen-drive amp...
Gordon.
Old 5th May 2008, 10:48 PM   #5
A user here Shoog has used power toroidals in a few amps and I can tell you they sound great. I think he goes for 4-5 times over the wattage.
Fran
Old 5th May 2008, 11:01 PM   #6
SY's Avatar
I would think that you'd have to have the transconductances matched pretty tightly for this to perform well.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 6th May 2008, 01:30 AM   #7
alexg's Avatar
Fran
I got the idea of using toroidal OPT from Shoog, and have been closely following his work.
I did a 6as7/6080 parafeed using a 40VA mains transformer and it sounded excellent!
Old 6th May 2008, 09:29 AM   #8
Shoog's Avatar
I am encountering the first serious issues with the Tabor clone I am currently building. I get big overshoot on all square wave leading edges. I needed to install a Zobel on the primary to tame this. I haven't got the same issue with other amps using the same transformers. I can only presume that the very low output impedance of the plate to plate design is interacting with the interwinding capacitance to over excite the transformer.
Certainly an issue to watch for and a good scope is needed to diagnose. Aparently there are no free lunches.
I also find that wiring up a transformer in one direction will induce ringing and then reversing the wiring will make it go away.
Shoog
Output (beam) pentodes / tetrodes suitable for screen grid drive ilimzn Tubes / Valves 19 15th June 2013 06:23 AM
FS: Toroidal Transformers BobG Swap Meet 2 25th August 2009 07:00 AM
WTB/S/T: Toroidal Transformers - UK deadparrot Swap Meet 5 16th June 2009 09:34 AM
Toroidal transformers muddy Class D 3 24th February 2005 11:23 PM
Best Transformers (Encapsulated Toroidal or Open Frame Toroidal) Rixsta Pass Labs 10 23rd April 2004 03:41 AM
Copyright 1999-2017 diyAudio
