Old 4th May 2008, 10:36 AM   #1
Default Best low-signal direct heated triodes?
Hi DIYs,
I was wondering what - soundwise - is considered the all-time very best low-signal direct heated triodes?
Any of you have suggestions?
It doesn't matter if they are no longer available - I am mainly interested in comparing their physical design (materials used, positioning of grid, anode, cathode, etc.) for another purpose (plasma-like microphone).
I'll appreciate if you have also suggestions as to where I can find pictures of their physical design on the internet.
Thanks,
Jesper
Old 4th May 2008, 12:18 PM   #2
I've been collecting small signal DHTs for over a year and now have boxes full of the stuff. My rank order would go something like
10Y
26 globe
201A
26 ST
01A
31
112A
30 globe
3a5
1G4G
1E4G
rest.
I didn't put in 71A, 45, 46 etc because these are primarily drivers. The 10Y is an incredible tube that can go anywhere in a system, even as input with lower voltage and current.
Old 4th May 2008, 02:38 PM   #3
Thanks! Looks interesting ...
Would you by any chance know where I can see pictures/drawings of their physical design? And maybe a description of materials used?
BTW I did a google search on the Y10 and found this website:
http://www.geocities.com/nikolic_lj_...ctronTubes.htm
Thought I'd mention it in case it is of interest ....
Jesper
Old 4th May 2008, 03:01 PM   #4
ncc is offline ncc
Send a message via Yahoo to ncc
Is there any difference between 10 and 10Y tubes?
I'm planning to make a #26 tube linestage but don't like #26 tube low voltage, hight current heater, so I'm probably going to make a 10/10Y linestage.
Old 4th May 2008, 04:36 PM   #5
Datasheets say:
10Y - max voltage 350v 10 watts
10 - max voltage 425v 12 watts
They look pretty identical. The VT-25 is the thoriated filament 10 or 10Y
The VT-25A is a longer plate version.
Old 4th May 2008, 06:15 PM   #6
I am seeing here (in spec sheets) astonishingly parallel Mu curves...
Very little lean to the right (if real tubes measure like the book).
As I've been studying, variances in Mu within the tube structure
cause the lean to the right as the lower Mu (remotest) parts of
the triode cut off last, with consequence of unenequal spacings
between curves along a resistive load line.
I see a trend: Flat sheet (rather than radial) constructed triodes
seem to have a lot less lean to the right (at least in the books).
And for the very same reason, the linearity is pretty good.
Any triode can have constant Mu with a constant current load.
Takes something special to have with other types of load lines.
Old 4th May 2008, 10:43 PM   #7
It's true that my top three - 10Y, 26 and 01A all have flat plate structures. They do look fairly similar. I've always thought that flat plates were the way to go, though I've liked a few round plates in the past. These days I find the same round plates a little tubby.
Old 5th May 2008, 03:03 AM   #8
jlsem is offline jlsem  United States
jlsem's Avatar
The Y in 10Y means it has a micanol base rather than a plain bakelite one. The VT-25A has a gold-plated grid to reduce secondary emission.
John
When an LP gets scratched it still makes sense; when CDs crack up they go completely senile and gibber incontinently. - Hugo Williams
Direct heating triodes are really better? Jaime Tubes / Valves 22 8th September 2006 02:40 PM
Spice 3f4 model of a low voltage direct heated signal level pentode wa2ise Tubes / Valves 0 24th April 2006 12:18 AM
cathode connection in directly heated triodes metebalci Tubes / Valves 2 21st March 2004 08:58 PM
Direct heated tubes with centre tap on filament mig-ru Tubes / Valves 2 13th May 2003 01:44 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
