For audio use, how do GE full metal 6CA7s compare to the glass version?
I have a few of these and I'm wanting to know whether they are worth keeping for DIY amplifier use. Thanks, Greg |
#2 |
Yo Gregg,
In all my years I've never seen or heard of a metal 6CA7. Did you mean 6AC7? Can you post a pix of one? Victor
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 |
Victor, Yes they are 6AC7s.
Excuse me while I turn a nice shade of red. I'm glad you replied or I might have not noticed that for a while. Funny how you see what you want to see sometimes. Thanks! |
#4 | |
But seriously, the only difference is that you have that nice orange glow with the glass versions, and you don't with the metal ones. In one project, I'm using metal 6J5s (Westinghouse JAN NOS) which are considerably less expensive than the glass ones, and they sound just great. The only other pecularities of this type are that you need DC heater power if using for low level audio amplification. You also need a stiff screen supply. A series dropping resistor doesn't cut it since this gives a variable-u characteristic that might be handy for AGC in an IF strip, but leads to inferior sonics. You definitely want at least a stiff voltage divider, or perhaps, those small panel neons or Zeners for screen regulation. The only other consideration is that the metal envelope is never allowed to become more positive than the cathode. Otherwise, it'll act like a second anode, and you definitely don't want that. |
#5 | |
It IS possible to get over 100 watts out of two 6L6's if you hook enough Eico power supplies together. It IS possible to get the metal can glowing red. This happens after all of the paint peels off of it! They don't live long under these conditions. Most metal tubes have the metal can connected to pin 1. Some amplifiers that were not designed for metal tubes may use pin 1 on the socket as a tie point for something like B+. (Stromberg Carlson PA amp) The foil on the cover of Steppenwolf's second album DOES conduct electricity, and it will fly all the way across the classroom when it touches the metal can of said 6L6! One of those moments that you don't forget!
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#6 |
Mr. Anderson, that's some funny, funny stuff.
I feel this bit of levity was, in part, due to me ineptly identifying my tubes. I insist I be given credit. |
#7 |
I imagine that another problem with metal can power tubes is that you can't look inside and see if the grid wires are glowing.
| Metal dome should always go with metal cone? Is this a rule? | Jay_WJ | Multi-Way | 5 | 5th February 2007 06:53 PM |
| where do you buy your metal?? | sts9fan | Parts | 9 | 13th October 2006 08:56 PM |
| ASC metal can polypro caps: ground the metal can to AC ground? | jarthel | Tubes / Valves | 10 | 6th September 2006 12:54 PM |
| Metal Oxide vs flamme proof vs metal film | ostie01 | Parts | 28 | 26th June 2006 06:38 AM |
| GEC Metal Cone | dominic | Multi-Way | 0 | 1st October 2004 04:02 PM |
