speaker that can be driven by tube amp
Old 4th May 2008, 02:04 PM   #21
Brett is offline Brett
Brett's Avatar
Originally posted by milen007
whats the max wattage 300b can produce? in push pull setup or other setup that can produce more wattage from the 300b? any hybrid 300b?
About 9W SE class A, double that for PP class A, maybe 35-40W AB1 and Jack Elliano reckons 50W in AB2.
Old 4th May 2008, 02:31 PM   #22
milen007 is offline milen007  Indonesia
with pp or ab setup, would the sound suffer compare with Single ended setup? narrower soundstage ? less dynamic?
Old 4th May 2008, 03:38 PM   #23
Evenharmonics is offline Evenharmonics  United States
I think those may have more to do with the speakers and room acoustics however, SE and PP amps do sound different. It comes down to personal taste.
Old 4th May 2008, 03:51 PM   #24
wicked1 is offline wicked1  United States
wicked1's Avatar
This isn't going to help things, but I built both a PP and SE amp over the past 6 months..
I consciously like the PP more, but I guess subconsciously like the SE more.
On initial listening, I like the PP. It seems to have faster attack, more solid bass. But for some reason, I always end up going to the SE. I can listen to the SE all day long, and barely pry myself away from it. I get tired of listening to the PP amp, just like any S.S. amp Ive ever had.
Old 4th May 2008, 04:06 PM   #25
that might be the charm of SE. can high sensitivity speaker say 96db, driven using SS or hybrid with high wattage say 100w?
Old 5th May 2008, 09:56 AM   #26
Brett's Avatar
Of course. My new speakers will be >102dB/W/m direct radiators and I plan on using highish power amps. I drove my Klipshorns with Pro PA amps for a while.
Old 6th May 2008, 07:36 AM   #27
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default Lotsa SPL!
The Cerwin Vega E715 "Big box" loudspeaker is rated at 102 Db @ 1M...and 'rated' at 400 Watts.
That comes out to 126 Db @ 256 Watts.......Downright brutal.
_____________________________________Rick......... .
speaker that can be driven by tube ampHide this!Advertise here!
Butler ? Tube Driven amp/s For free. selvol Car Audio 31 28th August 2009 09:26 PM
Digitally driven tube pre-amp eranrund Tubes / Valves 9 29th July 2008 08:12 PM
g2 driven tubes gianis Tubes / Valves 10 24th January 2008 05:30 PM
Tubes driven by BJT's drago Tubes / Valves 12 12th April 2006 09:35 PM
sub not being driven enough? dlagace Subwoofers 3 26th November 2003 12:26 AM
Copyright ©1999-2017 diyAudio
