| diyAudio Sponsor | ||
I have a ton of tubes for my amps. I now have a nice new tube tester and want to record the test results for each tube. I figure I'll keep the results on a spreadsheet and reference the tube by a number. It is easy for me to label the base of an 8 pin tube, but how can I put on something semi permanent onto a little 9 pin preamp tube, that won't screw with the tube or get mucked up by heat?
thanks d1 |
#2 |
Tektronix used a simple paper label on their tubes that seems to hold up under the heat. I thought it might be metal foil, but close inspection confirms that it's just paper.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 |
duh? I feel silly. Your reply made me think of the label maker I have in the office. I just checked - they say the labels can handle "extreme tempaeratures"
http://www.brother.ca/en/p-touch/civ...nated_tape.asp Not quite sure what "extreme" means, but I'll test it on a few (old) power tubes and find out! thanks |
#4 |
Let us know how it works! I've got a Brother label maker and labeling various tubes makes a lot of sense.
--Sherman |
| Serial or parallel | K-amps | Solid State | 19 | 12th November 2006 01:58 PM |
| Serial to I2C using MSP | stud | Digital Source | 2 | 17th May 2004 10:55 AM |
| use serial data | A'af | Digital Source | 2 | 16th January 2002 07:50 PM |
| Page generated in 0.07064 seconds (73.89% PHP - 26.11% MySQL) with 11 queries |
