| diyAudio Sponsor | ||
hey all. i've hacked together an interesting idea for a basic class a amplifier using a 6gn8 triode/pentode...
how's it look? any comments or suggestions? http://www.geekysuavo.org/throwbacks...lifier-1.0.pdf (it's also attached) some figures, which i'm assuming (??) to be relatively correct: triode section HT = 350V Rl = 120k Ia = 1.125 mA Va = 215V P(Rl) = 152mW Vin = -1Vpp Vout = 60Vpp Av = 60 Ra = 44.29 mu = 90 gm = 2.032mA/V Rk = 1.8k Vg-k = -2.025V P(Rk) = 2.3mW rk = rk || Rk = 901 Ck = 220uF f(-3dB/LF) = 0.8Hz pentode section Zl = 6.5k Va = 145V Vin = -2Vpp Vout = 125Vpp Av = -62.5 Ia = 31.54mA Pout = 6.5W ... is this correct? Ig2 = 15.5mA Ik = 47mA Rk = 53.6 Vg1-k = -2.5192V P(Rk) = 118mW Ck = 3000uF f(-3dB/LF) = 1Hz miller effect for pentode, Cag = 0.1pF Cmiller = (60 + 1) * 0.1pF + Cstray = 17pF for pentode, Rgl = 1M f(-3dB/HF) = 288 kHz i know that's just a lot of numbers, but i figured they may be of use. peace, ~ brad. |
#2 |
Your schematic doesn't match the data listed. Schematic has a B+ of 350V, but you list the pentodes anode voltage of 145V. Your transformers 6.5k impedance is AC, the DC resistance is probably less than 100 ohms. 350V B+ would exceed the plate and g2 voltage ratings, which is 330V.
The 6gn8's Pentodes plate is rated for 5W. That means the absolute most power you will be able to squeeze from it is 2.5Wrms (5Wpeak) in Pentode mode. But you will realistically probably end up with about 2W Pentode and maybe a little less in UL. That's with a properly designed circuit. There are some similar tubes rated for more power. I can provide numbers if they are of use to you. |
#3 |
In case you are new to transformer coupled stages, check out:
http://members.aol.com/sbench102/po-dis.html Keep in mind that your plate voltage will be the B+ (HT, whatever you want to call it) and subtract, bias voltage (for cathode bias) and subtract - (idle current*transformers DC resistance). You will find the voltage from the plate to ground to be pretty close to B+ at the operating point. Now the tricky thing is (when compared to resistor plate load), the plate voltage swings above(way above) your supply voltage (B+) when an AC signal is applied. |
#4 | |
Great site by the way.
#5 |
wow, thanks for the feedback! i wasn't getting any emails from the forums, so i'd assumed incorrectly that nobody had replied... oops.
ok, i do see that my operating voltage is much too high now. thanks for pointing that out. but since reactance (and thus impedance) of the output primary changes with signal frequency, how is there any chance that the frequency response of the power amplifier will be linear in the 20-20k range? i must be missing something here... ![]() just to make sure, the triode looks o.k., right? ~ brad. p.s. thanks about the site! |
#6 |
as a side note, i'm probably not looking for too much power output, since this is kind of my first design anyways... i suppose i could always go with a 12ax7/el34?
BUT, would 2W per channel even be enough to push two small 8 ohm speakers into reasonable volume?? thanks again for the help... ~ brad. |
#7 |
sorry for the barrage of posts... lol. i just figured out how loud you can make 2W depends on the sensitivity of the loudspeakers... good to know.
~ brad. |
#8 |
well, now that i'm thinking about it, what are these mystical similar tubes to the 6gn8/6eb8?
~ brad. |
#9 |
You might want to check out the latest issue of audioXpress (out today?). I've got an article on a similar amp in it. There is some data (schematics, etc.) on the design here:
http://www.pmillett.com/midget.htm The magazine article has the full construction details in it... Pete |
#10 | |
With a resisitive 8ohm load on the secondary- The reflected impedance on the primary is 6.5k. The inductance of the transformer is high enough to where its reactance isn't influential until the low frequencies. A good way to look at it is like this- the plate is loaded with a 6.5k resistor in parallel with a large inductor. At DC, the inductor is pretty much shorts out the resistor. But as frequency increases the inductors reactance becomes large, to the point of where it's like an open circuit. All that the plate will see is the resistor (which is the reflected impedance). The transformers inductance will determine the low frequency cutoff. For a given impedance, a transformer with a larger inductance will be able to extend lower in frequency. For a real world speaker load, where the impedance fluctuates, yes, the reflected primary impedance does vary. This will cause a non linear frequency response from a voltage standpoint. The amount of how much the output voltage fluctuates with impedance variation is how amplifiers output impedance is determined. An amplifier with a very low output impedance acts as a voltage source, where-as a amplifier with a high output impedance acts like a current source. |
| WTB: Single KT88-EH tube | quadtech | Swap Meet | 0 | 17th March 2009 01:31 PM |
| Tube-Mosfet Single-Ended Amplifier! | Matthewong | Solid State | 15 | 2nd October 2008 05:13 AM |
| single ended HiFi Regal stereo tube amplifier | karma | Tubes / Valves | 20 | 14th June 2005 02:59 PM |
| Single-end... which tube? | Mr. Triatic | Tubes / Valves | 56 | 25th December 2004 09:08 AM |
| Page generated in 0.11498 seconds (81.17% PHP - 18.83% MySQL) with 10 queries |
