| diyAudio Sponsor | ||
who do you graphically take the performance in a common anode amplifier? (no Ra, signal taken from cathode) thanks
i am currently using 60,000 uF of capacitance in my preamplifier.. |
#2 |
Draw loadlines as if you were taking the output from the anode, then apply 100% negative feedback by moving the load resistor into the cathode circuit.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#3 |
You can use the Ia/Vgk graphics.
But the CA gets more linearity when loaded with a current source. When the voltage between anode and cathode is held constant too, the linearity is even more improved Check the www.vacuumstate.com site for examples
Music is the best F.Z. |
#4 | |
From my experience of building both the hybrid and all tube FVP5 linestages (though mine were differential), this one sounds the best. I haven't tried the RTP3C linestage. http://www.vacuumstate.com/images/FVP5A.gif |
| 300B Cathode Feedback + Cathode Bias | korneluk | Tubes / Valves | 13 | 7th January 2009 09:07 PM |
| CCS on SE 2A3 cathode | albertli | Tubes / Valves | 5 | 14th July 2008 10:51 AM |
| UL to triode mode conversion on cathode bias amp-different cathode resistors needed? | bigwill | Tubes / Valves | 6 | 30th December 2007 01:37 AM |
| LED in cathode | Tubesin | Tubes / Valves | 60 | 9th October 2007 10:35 PM |
| Page generated in 0.09669 seconds (73.78% PHP - 26.22% MySQL) with 10 queries |
