| diyAudio Sponsor | ||
Hello,
I've got so much money tied up on my transformers and tubes, I don't want to mess anything up. . Otherwise, I'd just experiment w/out asking questions. So, just to be sure. If my output transformer primary is 3k, and I want it to act like it's 6k, I would connect my 8 ohm speakers to the 4 ohm tap? I just want to make sure I don;t have it backwards. thanks! |
#2 |
I am no expert, but I think that this is termed reflected load. If you had an 4 Ohm speaker on the 4 Ohm tap, the reflected load to the output valve would be 3K. Therefore if you double the load on the secondary to 8 Ohm, the load reflected to the output valve would also be doubled - to 6K.
So yes, I think you are correct. Chris |
#3 |
Yes, but...
...count on losing an octave from the bass response. For SE transformers especially, there is no free lunch - it won't perform as well as one designed for the 6K load. |
#4 |
Which begs the question, if you have so much money tied up in the output transformers, why did you not get the right ones to start with?
#5 |
HAH why indeed.....
really, I'm trying different tubes in my amp... Plus, I dont' fully understand the output transformers yet. I hope to learn something by trying different settings. There's such a wide variation between what people use. Some people say 5k sounds better than 3k for 300b, etc. |
| Quick transformer question | Brit01 | Tubes / Valves | 5 | 23rd July 2009 07:26 PM |
| Another quick transformer question | Hiwatt25 | Chip Amps | 6 | 8th February 2008 10:56 AM |
| Quick Transformer Question | krzanik | Tubes / Valves | 2 | 17th May 2007 09:15 PM |
| Quick wiring question! | toastytoy | Multi-Way | 4 | 18th April 2007 10:27 AM |
| Quick Output Transformer Question | dsavitsk | Tubes / Valves | 5 | 20th April 2006 07:08 AM |
| Page generated in 0.07543 seconds (71.65% PHP - 28.35% MySQL) with 10 queries |
