| diyAudio Sponsor | ||
Hi, this is my first post on the board.
Does anyone know where i can get a schematic or kit (very cheap) for 6922 / 6dj8 tube? The reason i'm asking is.. 1. I would like a tube preamp, and use solid state for the rest. 2. I have over 3000 (yes three thousand) of these tubes I'll give you some info on the tube, there "National" branded and are made in japan. Even if nothing comes of this tubes of any make are better then money in the bank and return a better investment. Oh, if you would like to relive me of some, please leave a message. However, that is not the primary reason for this post and i do not want to be shot down as trying to sell something in this section. |
#2 | |
diyAudio Senior Member
Welcome, For a preamp based around the same tube: 6922 Quote:
If the branding is red it could that these tubes were made for them. If you want to sell on the forum than there is the "Trading Post" section on the forum. Cheers,
Frank |
#3 |
I was hoping for a schematic
#4 |
DIY !
#5 |
#6 | |
If you need to attenuate because of too much signal, I'd prefer to do it at the output (for SNR reasons) and use short, low capacitance interconnects. For the same reason, I'd up the cathode R to about 270 ohms (Vg = -2.9V) so that the stage is less likely to clip on most input signals. The beauty of DIY is you can try it with an atten at the input and output, different biassing etc and see what you think. The stupidly expnesive CJ ART preamp is only 10 6DJ8's in parallel. You have enough tubes..... |
#7 |
I've seen some people using 6922s for low power (headphone) amps. I wonder if having so many might be an excuse to build a massively parallel OTL amp... Frank?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 | |
The 6922 is far from the ideal candidate for OTL use, you'd need tons of them to get the Zo down to useable levels. Well, if the tubes were mine I'd put some up for sale/swap and get some tubes that would fit a usefull diy project instead. Unfortunately they're not mine. Good use could be: a preamp, the headphone amp Dave refers to (actually the headphone amp can easily double as a preamp too), Input stage or phase splitter in an amp, output stage in a tube DAC.... Cheers,
Frank |
#9 |
on www.headwize.com; http://headwize2.powerpill.org/proje...=cmoy5_prj.htm is one nice preamp/headphone amp. I was building this, good sound, but very depend of tubes manufacturer. (I make some changes). Regards |
#10 |
yea but how much is one of those??? i'm not selling my left nut to get a preamp.
| SE Tube Preamp circuit using 6922/6dj8 at low voltage(24volt) needed! anyone? | tone | Tubes / Valves | 7 | 20th February 2010 01:11 AM |
| 6DJ8 / 6922 tube? | nordhaven | Tubes / Valves | 25 | 27th April 2008 09:07 PM |
| FS: NOS Amperex 7308 (6dj8/6922) PQ | dsavitsk | Swap Meet | 0 | 12th May 2006 01:39 AM |
| WTB: New Production 6922/6dj8 Tubes | mrdon | Swap Meet | 0 | 14th October 2005 04:49 PM |
| WTB: 6DJ8 / ECC88 / 6922 Tubes | mrdon | Swap Meet | 0 | 6th September 2005 10:58 PM |
| Page generated in 0.15921 seconds (84.13% PHP - 15.87% MySQL) with 11 queries |
