diyAudio Sponsor
Old 29th April 2008, 12:54 PM   #1
zigzagflux's Avatar
Default Stray capacitance of CCS
Using a Supertex DN2540 CCS in the tail of a differential pair, with a negative supply for a little extra headroom. Input signal is ground referenced.
Would like to mount the CCS assembly to the aluminum top plate by the heatsink; so a small heatsink will conduct its heat to the top plate. I should be able to dissipate quite a bit of heat with this method, and it makes for ultra simple mounting.
Question is regarding the thermal pads used to isolate the drain of the FET from the heatsink. With a dielectric constant of 2.4, the capacitance of my pad is around 0.2249*2.4*0.375/0.009 = 22.5 pF.
Not a ton of capacitance, but more than I would have if the heatsink were not bonded to the chassis.
How do I quantify the affect this capacitance to ground has on the differential pair?
Thanks !
Old 29th April 2008, 12:59 PM   #2
oshifis is offline oshifis  Hungary
The capacitance will be formed between the tied cathodes (a low impedance point) and the ground. It will have negligible effect. Other thing if the CCS were in the anode.
Too much capacitance? HaLo6 Power Supplies 24 14th June 2009 05:55 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 01:30 AM
Capacitance ak_47_boy Planars & Exotics 11 17th April 2008 08:16 PM
Stray capacitance in audio circuit ? gaetan8888 Solid State 8 10th June 2007 05:38 AM
How capacitance much and where? jaudio Chip Amps 1 24th March 2005 05:49 PM
Page generated in 0.05965 seconds (67.00% PHP - 33.00% MySQL) with 10 queries
