Old 28th April 2008, 02:35 AM   #1
Default Chinese Tube Amps?
Hy guys, i found some factories that build/sell Tube amps at not so high price. Can someone tellme if some of these can be good products?
What specs i need to see to check if are good or no ?
Old 28th April 2008, 03:16 AM   #2
samsagaz,
fisrt, U must considerate most china factory made tube amp was use OLD parts, used capacitors from E-waste market.
such as the OPT core lamination. They re-use used lamination from large power plant transformers & use mount to get the size of laminations that they prepare for OPT.
But this Old lamination was low efficiency, high core loss!
pls considerate roast bread will not cheaper than bread powder!!!
thx
Old 28th April 2008, 03:39 AM   #3
sorenj07's Avatar
Quite possibly, but if they have published specifications on things such as OPT's then I'd have no qualms other than shipping charges.
Old 28th April 2008, 03:42 AM   #4
vax9000 is offline vax9000  United States
tube-lover must be an expert of tube amp business in China.
What I know is that they turely"re-use lamination from large power plant transformers". However, they may not be "low efficiency, high core loss". Also I heard that higher-B lamination may not sound better.
Old 28th April 2008, 04:01 AM   #5
hi vax9000,
I am not say chinese OPT re-used large power plant lamination was not good. But can they know or gurantee the lamination was not overload or over heat.
Although Japan audio transformer was made in china now. But different standard.
pls understand.
pls see the picture/
use large OLD power plant lamination prepare for small size laminations.
I was OEMer of japan OPT.
I will continous post Japan audio grade OPT used material coming!
thx
thomas
Old 28th April 2008, 06:35 AM   #6
Lowrider's Avatar
I had Cayin, and now have Classic, both make good amplifiers...
Old 28th April 2008, 08:11 AM   #7
ja2dhc is offline ja2dhc  Japan
Send a message via AIM to ja2dhc Send a message via MSN to ja2dhc Send a message via Yahoo to ja2dhc
Default Re: Chinese Tube Amps?
Recently, I purchased a Chinese Power Amp which I introduced in my blog below (in Japanese).
http://ja1cty.at.webry.info/200803/article_7.html
I purchased it by only 400USD and its sonic is GOOD.
The circuit schematic is indicated in the manufacturer's web page below in which you can find the schematic at the bottom of the page.
http://www.xshn.com/office/cpshow.asp?id=383
The ORIENT CORE is used for OPT, as is described in the schematic. "Z11" is a part name of ORIENT CORE by "Nippon Steel Corporation" which is the largest transformer core material supplier in the world.
Old 28th April 2008, 02:08 PM   #8
Will ask the factory what kinf od core they use (hope they dont lie me)
Any brand from china to recommend me?
Old 28th April 2008, 03:14 PM   #9
Default chinese tube amps
Consider this: every piece of high quality clothing you are wearing probably came from China... and they were made at excellent prices and horrendously marked up in the west.
Chinese tube amps are no different. I purchased a Yaqin Mc100B and it is a great amplifier. Great detail, wide soundstage ect. I bet you that a year from now we won't be getting the Chinese amps at such great prices once they are distributed locally. Once that happens along with the corresponding price increase, the reviews will say that they are the best thing since slice bread.
Old 30th April 2008, 06:52 AM   #10
Default BEZ has done good by me
2 preamps and 805 based sets perform well to my opinions
Chinese Tube Amp? bsgd Tubes / Valves 65 5th March 2008 06:44 PM
chinese tube amp squirtacious Tubes / Valves 36 10th November 2007 04:06 AM
chinese and tube Depot amps? juanito Tubes / Valves 4 1st December 2006 08:57 PM
sources on the web for chinese amps lt cdr data Tubes / Valves 3 8th February 2006 03:11 PM
Chinese Tube Amp & DIY .. Pro & Con zxx123 Tubes / Valves 6 18th January 2005 09:54 AM
Copyright ©1999-2013 diyAudio
