diyAudio Sponsor
Old 27th April 2008, 01:19 AM   #1
wicked1 is offline wicked1  United States
wicked1's Avatar
Default blue glow on one channel
One of the tubes in my amp has always had a blue glow. Today I finally decided to do some testing, and swapped tubes, and still, the right channel was the one glowing.
I even used a different type of tube, and same thing.
I checked the current and voltage on both channels, and they are exactly the same.
this is a 300b se amp.
What else could cause this if the voltage and current are the same?
thanks!
Old 27th April 2008, 02:19 AM   #2
SY's Avatar
http://www.jacmusic.com/html/article...w/blueglow.htm
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 27th April 2008, 04:07 AM   #3
wicked1's Avatar
Well I know it's not gassy, and it's nothing to worry about, but I haven't found anything that says why one channel does it. It's not dependent on the tube, but on the channel.
Thanks for the link. I hadn't seen that particular site. Lots of great glowing tube pictures!
Old 27th April 2008, 04:32 AM   #4
m6tt is offline m6tt  United States
Have you tried replacing the coupling cap? It's a long shot, but I've seen weirder.
Old 27th April 2008, 05:36 AM   #5
vax9000 is offline vax9000  United States
Would a high frequency oscillation cause the problem?
Old 27th April 2008, 05:40 AM   #6
I've seen weird loading cause blue glows otherwise unexplainable as well. Maybe back emf from a transformer?
Old 27th April 2008, 05:19 PM   #7
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
It's normal for some tubes to glow, if it is on the inner glass surface. Although, that's weird that it's always on one channel even when switching tubes. I've seen oscillation cause blue glow between the plate and the cathode, but not on the glass surface.
Read this link.
http://members.aol.com/larrysb/blue_glow.html
Here is a picture of one of my amps that glow. Sorry for the size
Old 27th April 2008, 11:02 PM   #8
kevinkr's Avatar
Differences in the local magnetic fields around the output tubes? Just a thought..
www.kta-hifi.net
Old 29th April 2008, 12:00 AM   #9
New 6BG6GA's All 6BG6GA's I have are showing some blue glow.
They test and work normally. Besides being SY's favorite tube they just cannot be bad.
How about the way the tube is put together?
Old 29th April 2008, 12:12 AM   #10
SY's Avatar
Nice ST-70 there!
Blue glow confused :( bobhayes Tubes / Valves 50 20th January 2007 05:00 PM
New WE 300b's blue glow TubeHound Tubes / Valves 26 31st March 2003 01:22 PM
EL34 Blue GLow stigla Tubes / Valves 1 27th December 2002 05:06 AM
Blue Tubes the glow jleaman Tubes / Valves 34 6th August 2002 11:07 AM
Page generated in 0.10087 seconds (76.37% PHP - 23.63% MySQL) with 11 queries
