#21 |
Yes, that ripple is almost certainly grounding. That's the rectifier charging the caps. Time to get out the soldering iron!
Dietz's paper was called, "Understanding and Reducing Noise Voltage on 3-Terminal Voltage Regulators." Originally appeared in EDN. Somewhere on the forum, I posted an exact reference... edit: Werner Ogiers showed some nice plots: http://www.tnt-audio.com/clinica/reg..._noise2_e.html
If there's a sucker born every minute, where do the rest of them come from? |
#22 |
Sy
I am making tests to find the origin of the problem, incidentally I now use R5 = 120R to get 10mA, but it does not change much. >> Dietz's paper was called, "Understanding and Reducing Noise Voltage on 3-Terminal Voltage Regulators." Originally appeared in EDN. Somewhere on the forum, I posted an exact reference... << Do you have a copy of that article ? Regards Rollo |
#23 |
No, bringing up the current won't help a grounding/layout issue. If you have any pics and/or diagrams, perhaps one of the eagle-eyes can spot the problem.
#24 |
Hi
I made some progress, I changed the lower resistor of the reference with 2 150 V Zeners + 1 18 V Zener, a 10 uF 350 V cap across them and it is much much better, hiss and ripple is only about a few mV, looks like random distribution, visible with a 100 gain opamp only. The noise is noticeable only 30 cm from the loudspeakers and is proportional to the volume position. I guess now I have to add some cap at the B+ point and start to upgrade the caps/resistors on the line amp one channel at a time. I cut off the tone control and I will later go with the Spice upgrade (add 1 valve as a buffer) mod but only after I get some decent sound from the standard caps/resistors upgrade. Any suggestion ? Regards Rollo |
| preamp suitable for Dynaco st-70- OTHER than dynaco | namatjira | Tubes / Valves | 3 | 22nd December 2011 01:21 AM |
| Hiss but no hum... | RockysDad | Tubes / Valves | 13 | 5th April 2009 05:35 PM |
| Hiss in my P3a Amp | blap0220 | Solid State | 15 | 1st June 2007 01:52 AM |
| Pluto hiss? | cuibono | Multi-Way | 15 | 19th November 2006 04:19 AM |
| hiss | jaudio | Chip Amps | 21 | 6th March 2005 05:02 PM |
