diyAudio Sponsor
Old 26th April 2008, 01:35 AM   #1
itsmejto's Avatar
Default Got the build itch again. 80w kt88
Stumbled on a stripped dynaco st-70 chassis.
Decided to put it to good use.
Should deliver about 80 watts a channel if my last one was anything to judge by.
Using a Welbourne pcb (slightly modified) with 12ax7's and 6u8a's
Plate voltage arround 600vdc at 400ma
Yes, tube life will be limited, but it's for Ebay when done.
Old 26th April 2008, 01:50 AM   #2
Brett's Avatar
Default Re: Got the build itch again. 80w kt88
600V @ 100mA/tube will give them a very shot life.
Old 26th April 2008, 01:54 AM   #3
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Note to self: don't buy KT-88 amp from ebay
Old 26th April 2008, 02:01 AM   #4
Brett's Avatar
I was thinking the same thing myself........
Old 26th April 2008, 03:38 AM   #5
Ty_Bower's Avatar
...600vdc at 400ma
Uh, is that kind of power transformer gonna fit in the hole?
Old 26th April 2008, 03:46 AM   #6
tubelab.com's Avatar
Lets see, 60 watts of dissipation per tube, 240 watts total in the output tubes. The whole amp will melt if the rectifier tube doesn't blow up first! I have been known to bend some tube specs a bit (OK a lot) but I haven't found a KT88 that can deal with 60 watts. The best are EH KT88's and they glow dimly at 45 watts, brightly at 50 watts. They wouldn't last long (a few hours maybe) at 60 watts.
Power transformer? No, you are going to need a nuclear reactor.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 26th April 2008, 04:40 AM   #7
sorenj07's Avatar
If I had a quad of KT88's and wanted to get 80W out of them, I'd probably build monoblocks and transformer couple a 6V6 or something and run into class AB2. Might be feasible then...
I'm interested in how long this amp would run after being switched on. 10 seconds? 30? Unless of course there was a typo in the first post..
Old 26th April 2008, 05:45 AM   #8
HollowState's Avatar
I have a pair of mono blocks that run NOS GE 6550A's in ultralinear with at least 610 volts at 60ma per tube. I can get 100 watts rms out down to 60 Hz with the Acrosound TO-600 4K P-P load. 100 ma is too much and not necessary. However, I would be very afraid to try this with todays garbage 6550/KT88 tubes.
"The human race is just a chemical scum on a moderate-sized planet orbiting round a very average star in the outer suburb of one among a hundred billion galaxies." ~Stephen Hawking
Old 26th April 2008, 04:16 PM   #9
itsmejto's Avatar
oh my, such negativity.
Guess none of you ever saw a Harmon Kardon Citation II then.
Granted it has superb transformers, though it does run as standard at 65wrms per channel with old rca 6550's.
The last one I had was biased at 85ma and sounded both loud and clean, with the original 6550's from 30 years ago. I still use them on a daily basis in my home system and they havn't burned up yet.
As for the rectifier burning up, check out the specs on a 5au4, it may surprise some of you. (1400v @ over 1a peak) but granted it would be a weak spot pushed so hard I may have to use schottkies.
I'll be using EI-kt90's which should handle the extra load, check out the specs on em, they are not toys. the kt88's are just a set of test tubes to make the layout look better. As for the power tansformer, it's an Antec 800va (5-1/4" dia. x 4" tall) toroidal mounted on it's edge and should fit fine.
Old 26th April 2008, 05:48 PM   #10
Jeb-D.'s Avatar
You should check out the kt90-EH. The EI's are said to be great, but there is a large amount of defective ones floating around. I think the kt90-EH look better than kt88. I'm curious how they sound.
new build - abdellah SE KT88 vince76 Tubes / Valves 19 31st July 2009 11:07 PM
KT88 se build NO GAIN please help soundbadger Tubes / Valves 1 25th February 2008 05:52 PM
Stereo Build - Mikaels KT88 matthew2456 Tubes / Valves 11 24th January 2007 05:56 PM
suggest a KT88 SE to build matthew2456 Tubes / Valves 4 5th August 2006 06:23 PM
Using KT88 to build a monster champ amp? G Tubes / Valves 2 13th December 2004 06:20 PM
Page generated in 0.12089 seconds (79.38% PHP - 20.62% MySQL) with 11 queries
