diyAudio Sponsor
Old 25th April 2008, 02:36 AM   #1
zigzagflux's Avatar
Default Differential stage biasing choice
Hello:
See attached. Questions are pretty simple, but feel free to add 'why' reasons, as it's helpful to know the reasons for what we do.
1. Which scheme would you use, top (CCS) or bottom (resistor)? My leaning is for the top.
2. For CCS biasing, is the capacitor necessary? It seems to me, there is absolutely no effect it will have on the circuit.
Thanks !
Old 25th April 2008, 03:09 AM   #2
1. In theory the top circuit is better because the current source has a higher impedance (resistance).
2. The cap should be eliminated. For AC purposes "it looks" like it is between the cathode and ground. Thus at higher frequencies it will shunt the cathode to ground impedance. You don't want this.
Old 25th April 2008, 07:01 AM   #3
Hello zigzagflux,
please have a look here link .
What about a mixture from Western Electric PP and Differential (forced balance) ?!
Kind regards,
Darius
Old 26th April 2008, 01:42 AM   #4
zigzagflux's Avatar
Okay, that confirms that I can get rid of the capacitor (a good thing IMO- one less source of coloration and endless part swapping).
I'll have to mull over the forced balance option at Lynn's site. Anyone try this very design? His Amity/Karna designs are a little different from this topology.
Differential filter circuit: biasing problem Alex M Tubes / Valves 4 5th May 2009 09:44 AM
Self-biasing class AB input stage Mr Evil Solid State 56 25th April 2009 07:53 PM
Input stage biasing - BJT steve_mak Solid State 24 11th July 2007 03:38 AM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Page generated in 0.05964 seconds (80.33% PHP - 19.67% MySQL) with 11 queries
