diyAudio Sponsor
Old 23rd April 2008, 11:50 AM   #1
davorin is offline davorin  Croatia
Wink 300 KW tube audio amplifire-modulator
Hi! Here is some photos from 300KW audio-modulation PP-AB1 tube output from AM broadcasting transmitter ZadarSV1200. (2x600KW VF ClassD tube transmitters, plus 2x300KW audio-modulation tube outputs with 2 modulation transformers)
File Type: jpg fil.transf. and sockets of mod.tubes from zadarsv1200.jpg (42.3 KB, 760 views)
Old 23rd April 2008, 11:58 AM   #2
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Wow..that is big...have you got any more pictures?
Old 23rd April 2008, 09:42 PM   #3
Yes, but I don't know how attachment more than one picture!
Old 23rd April 2008, 09:46 PM   #4
Here is more!
Old 26th April 2008, 05:34 AM   #5
C1 and C2 from HV-PS (CLC filter) have 6x24microF/25kV parallel each.
File Type: jpg c1 and c2 from hv ps from zadarsv1200.jpg (41.4 KB, 438 views)
Old 26th April 2008, 05:38 AM   #6
HV rect. unit with 12 block (12 thyristor each bloch) for 12kV/120A.
File Type: jpg hv rect. unit from hv ps from zadarsv1200-1.jpg (49.9 KB, 413 views)
Old 26th April 2008, 05:40 AM   #7
L from CLC filter of HV-PS (8,6H/120A)
File Type: jpg l from clc hv-filter from zadarsv1200.jpg (42.9 KB, 393 views)
Old 26th April 2008, 05:42 AM   #8
Main HV transformer 1,6MW(Prim.:3x20kV/Sec.:3x10,6kV)
Old 26th April 2008, 05:44 AM   #9
Left output tube.
Old 26th April 2008, 05:53 AM   #10
Filament transformer (Sec.:8,6V/860A) for left output tube and socket with parts of grid and screen socket connection.
1,25kW tube amplifier/modulator davorin Tubes / Valves 15 7th May 2008 02:51 AM
5.1 amplifire for surround silvezoki Parts 3 1st May 2007 12:09 PM
Audio-To-Light Modulator iOrion Car Audio 3 27th April 2006 07:44 AM
BCA modulator design? mzzj Class D 7 9th August 2005 02:35 PM
FM modulator schematics? Tazzy Car Audio 4 17th May 2003 11:26 PM
Page generated in 0.10074 seconds (74.74% PHP - 25.26% MySQL) with 11 queries
