diyAudio Sponsor
Old 21st April 2008, 12:03 AM   #1
Default 6au6 Cf
When using a pentode such as 6AU6, or EL84 for that matter, for CF service is it really worth the hassle of using pentode mode or is triode wiring nearly as good? I am thinking of using a 6AU6 as a 3rd order LP ala Steve Bench for a subwoofer output but I also have a spare Chinese EL84 clone that could be used also I just don't whether all the bother of pentode mode is worth it.
mike
Old 21st April 2008, 07:23 AM   #2
Mike,
absolutely worth it.
The screen grid (g2) MUST be tied at AC to the cathode by a capacitor.
Weird but true - if you don't do that, then it is the triode mode characteristics of the pentode which apply to its analysis and performance.
In order of performance,
triode CF
triode CF with current source load (either tube or SS current source)
pentode CF
The definitive text / maths etc can be found in Wallman and Valley.
If your a bit of a heretic then MOSFET Source Follower is theoretically even better.
Ian
Old 21st April 2008, 07:31 AM   #3
AKSA is offline AKSA  Australia
Hi Ginger,
How about driving the screen grid on a CF at around 50% of the AC voltage at the cathode?
In one sense, this is half way between triode and CF follower, wonder how that would sound?
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 21st April 2008, 10:19 AM   #4
So you would connect screen grid to b+ (same B+ as Plate?) via a smallish resistor and to the cathode with a cap that is of sufficient size to short all AC to the cathode?
mike
6AU6 pentodes TGRANT Tubes / Valves 20 6th March 2009 12:22 AM
better 6au6 alternative nhuwar Tubes / Valves 6 6th February 2007 06:10 PM
6AU6 Varieties wrenchone Tubes / Valves 2 13th January 2007 10:49 PM
Anyone know the g1-g2 capacitance of 6AU6? ray_moth Tubes / Valves 10 29th August 2004 07:19 AM
Page generated in 0.07565 seconds (71.95% PHP - 28.05% MySQL) with 10 queries
