diyAudio Sponsor
Old 19th April 2008, 02:49 PM   #1
Default I'm Looking for this Similar Schematic !
this is small and tiny amp.
I'm looking for this small tube amp schematic... if anyone can suggest me ?
http://www.6moons.com/audioreviews/muvac/muvac.html
or
http://www.yourmaclifeshow.com/node/195
cal
be tube
Old 19th April 2008, 04:18 PM   #2
http://www.roehrentechnik.de/html/kolibri.html
Regards Andreas
Old 19th April 2008, 04:23 PM   #3
korneluk's Avatar
Not the same amp, but similar tubes.
Enjoy,
-- josé k.
Old 19th April 2008, 04:27 PM   #4
korneluk's Avatar
Another 5902 creation...
http://www.jogis-roehrenbude.de/Lese...rmann-Mini.htm
Old 20th April 2008, 11:34 AM   #5
Thankyou guys for the quick reply,
some questions before I start to choose which one I will build:
1. where to buy that OT Transformer ? I can't find locally.
2. which one is better between two ? in term of sound quality, looks like the Kolibri is better ? why ? proven ?
3. any recommended speaker ? like 103dB ? I have 100 Coral speaker but not good at all. any better than Fostex ? beside Lowther ?
4. which one cost more between two ?
thank you again
cal
be tube
Old 20th April 2008, 11:57 AM   #6
The circuit design and transformers 53.43 (32 Euros each) are from Gerd Reinhoefer:
http://www.roehrentechnik.de/html/bastel-au.html
Peter Grundig has changed the input tube to the 5744 an designed a new case for the µVAC.
Regards Andreas
Old 20th April 2008, 02:03 PM   #7
that's quick, thanks.
I saw this http://www.roehrentechnik.de/
I wonder where is the Schematic and the power output ? the Darling amp.
does it sound better ?
cal
be tube
Old 21st April 2008, 03:48 AM   #8
Andreas,
any idea why he change the input tube ?
better result ?
seems like you know this guy, can you suggest me which to build for me ?
cal
be tube
GU29 Amp. Schematic - Audioromy or similar poynton Tubes / Valves 4 5th March 2008 07:26 AM
similar to SKA djk Solid State 6 7th June 2007 03:28 PM
looking for similar FET Ahmad_tbp Solid State 5 6th May 2006 09:26 PM
Tune Dem or similar anyone? Jussi Everything Else 0 3rd January 2006 08:59 AM
Similar DC/DC coverters? eeka chu Digital Source 1 20th April 2004 08:49 AM
Page generated in 0.09039 seconds (76.91% PHP - 23.09% MySQL) with 10 queries
