photomultiplier tube - what is this???
Old 18th April 2008, 04:23 AM   #1
awedio is offline awedio  United States
awedio's Avatar
Default photomultiplier tube - what is this???
Have a look at this...
http://www.allelectronics.com/cgi-bi...IER_TUBE_.html
Any possible audio uses?
"Where is my mind? Where is my mind? Wheeere is myyy mind? Waaay out, in the water, see it swimmin'..." Black Francis
Old 18th April 2008, 04:58 AM   #2
JohnAtwood is offline JohnAtwood  United States
JohnAtwood's Avatar
Default Photomultiplier
Audio uses - not much. An earlier version of this tube (the RCA 931A) was used as a white noise generator in WW2 counter-measures transmitters. It is mainly used where a very faint light signal needs to be detected.
- John Atwood
Old 18th April 2008, 06:09 AM   #3
gingertube is offline gingertube  Australia
Other variants of this tube also used to be used to "read" the audio track off film in very early film projectors.
I use a $5000 version as the heart of a laser receiver to look at laser reflections from the sea bottom in a Laser Airborne Depth Sounder survey system. I put down 5 Megawatt, 5 nanosecond wide laser pulses (frequency doubled Nd:YAG laser) and can see bottom reflections from up to 70 metres deep in clear water. One of the boffins here did some calcs and determined that we put out so many 10's of millions of photons in each laser pulse and we need to get 10 of them back for the photomultiplier tube to generate enough signal for us to determine how deep the bottom was.
Photomultiplier tubes are still the most sensitive light sensors known to science.
Ian
Old 18th April 2008, 02:54 PM   #4
DaveInVA is offline DaveInVA
They were also used in early computer card readers to read the holes in the card. They were also used in readers that would read those forms you'd fill in the little ovals with pencil marks for the answers...
Dave
Old 18th April 2008, 05:31 PM   #5
woodturner-fran is offline woodturner-fran  Ireland
Variants are also used in some scientific equipment - pulsed flame photometric detectors and that sort of stuff.
Last one I bought was 700 or thereabouts.
Fran
Old 18th April 2008, 05:40 PM   #6
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Look at the Hamamatsu website -- fascinating stuff -- i bought a bunch of PMT's and unloaded them just a year ago -- you could buy 931's for a few dollars, and sometimes the more exotic devices were almost given away.
got muons?
Old 18th April 2008, 05:59 PM   #7
pmillett is offline pmillett  United States
pmillett's Avatar
Default Re: Photomultiplier
John, that sounds like a challange...
Light-activated tube theremin, perhaps?
Pete
Old 18th April 2008, 11:06 PM   #8
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Photomultiplier tubes are much posher than you might think. Broadcasters used to use them in telecines (film to video) because they provide extremely low noise amplification and high bandwidth. Physicists use them for all sorts of stuff, attempting to detect neutrinos springs to mind (you find a deep mine shaft, fill it with water, and hope to catch the scintillation as a zillions of neutrinos pass through).
You have to be very careful with PMTs. Expose them to light with power applied and they self-destruct. They have enormous gain - 10,000 or more is typical depending on dynode voltage and number of dynodes. Oh, and they're expensive. I replaced a blue telecine tube costing 1500 in 1988.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 18th April 2008, 11:37 PM   #9
fizzard is offline fizzard  Canada
Also used in combination with scintillation crystals to detect radiation. A PET scanner has a ring of scinillation crystals around the bore of the machines, each with its own photomultiplier. They can detect a single photon of incoming gamma rays.
As far as self destructing when exposed to bright light with the power applied I done this myself with no ill effect.
Old 19th April 2008, 12:43 AM   #10
audio-kraut is offline audio-kraut  Canada
Right. Beckmann used them in their scintillation spectrophotometers, to detect afair alpha and beta radiation from "labelled" molecules.
photomultiplier tube - what is this???Hide this!Advertise here!
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
Octal tube as headphone amp output tube yagoolar Headphone Systems 6 25th November 2006 09:11 PM
tube driving the same tube - whats the collective word? zobsky Tubes / Valves 3 13th June 2005 06:47 AM
Copyright ©1999-2017 diyAudio
