diyAudio Sponsor
Old 16th April 2008, 06:45 PM   #1
Question McMartin MA-20 mods
I seem to have a problem posting. I am going to try a shorter post this time.
Attached is a schematic for the amplifier. I am looking to make some changes, and I am open to suggestions. I am interested in turning this into a guitar amplifier.
Already planning and ready for:
1. Change AC power cable
2. Change to 1 input jack (1/4")
3. Change to 1 output jack (1/4")
4. Standby switch (is this really necessary?)
Need assistance with:
1. Preamp redesign
2. Addition of Presence Control
3. Effects loop
4. Bias adjustment pot(s)
Any assistance would be greatly appreciated. I have specific ideas I'll post once I have determined that I can ACTUALLY POST!!!
Thanks,
Mark
I don't feel tardy
Old 16th April 2008, 07:53 PM   #2
It appears I can now post. GREAT!
In reference to my original post, I have an idea in my head for the preamp, but I need some technical advice on how to make it happen. Here's what I had in mind:
input---1st gain stage---volume---dpdt bypass switch---2nd gain stage (switched)---dpdt bypass switch---3rd gain stage (switched)---tone stack---4th gain stage---PI and power amp
The idea is that I'd like to have an amplifier that can do clean/crunchy/wild/full-tilt with the flip of a couple of switches. I think it would be really cool to have the 2nd and 3rd stages "voiced" differently, so that I could effectively have 4 distinct sounds (1+4, 1+2+4, 1+3+4, and 1+2+3+4) in the same chassis. All this, of course, before I ever even hit the power section!!!
I don't fully understand impedance matching, so I have no idea what resistor/capacitor values I should use in the stages or in the coupling sections, or what affect different values will have on the sound characteristics of the different stages.
So, am I totally nuts, or can this be done? Should I consider a different order (like the tone stack after the last stage just before the power section, for instance)?
If it works, would this be footswitchable with the addition of shorting jacks and a custom footswitch?
I don't feel tardy
random crackle ? (McMartin MA-20) the fuhz Tubes / Valves 3 14th March 2008 09:54 PM
McMartin MA-20? porkchop61 Tubes / Valves 14 15th August 2006 03:39 PM
McMartin MA-50 Troubleshooting whitfiel Tubes / Valves 14 9th June 2005 12:07 AM
McMartin Reciever model TR-E5 need wiring diagram and operation manual thee8track Solid State 0 8th June 2005 03:30 AM
Page generated in 0.07018 seconds (70.60% PHP - 29.40% MySQL) with 11 queries
