Best/favorite CF NOS noval twin triode?
Old 16th April 2008, 05:51 PM   #1
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
Default Best/favorite CF NOS noval twin triode?
What I am looking for is a recommended NOS twin triode in the "standard" noval pinout (12AU7 etc.) for a cathode follower.
I know about the standard forum recommended 6N6P (not NOS) and 5687 (different pinout). I know 12AU7 is often called an "OK" CF tube but I was wondering if there was something better. Larger heater draw or different voltage is no problem.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 16th April 2008, 05:56 PM   #2
On Hiatus
SY's Avatar
The figure of merit is gm, but you also have to consider desired drive current- a tube with 1mA of plate current won't drive a 1k load very well no matter how high the gm. For general purpose applications, it's tough to do significantly better than the ECC88 if you're limited to a dual package.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 16th April 2008, 06:25 PM   #3
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
That leaves the 8416 -- it is a 6dj8 with a 12.6V heater, which means it is pin compatible with the 12au7 with the exception that the heater has no center tap. So you have to use 12.6V to heat it.
Old 16th April 2008, 06:34 PM   #4
On Hiatus
SY's Avatar
Shhhh! We don't talk about that tube!
Old 16th April 2008, 06:37 PM   #5
dsavitsk's Avatar
Oops, sorry. I forgot.
For what it's worth, I don't know that anyone is making 6N6p's anymore. they are NOS, just not US or EU made NOS.
Old 16th April 2008, 06:40 PM   #6
kstagger is offline kstagger  United States
kstagger's Avatar
12BH7?
ok - not exactly a high transconductance tube.
Old 16th April 2008, 06:47 PM   #7
dsavitsk's Avatar
How about a 6DT8 or 12DT8. mu = 60, Gm=5500, and they are like $3 each.
Old 17th April 2008, 09:29 AM   #8
Tubes4e4 is offline Tubes4e4  Germany
Tubes4e4's Avatar
Hi Stuart,
Indeed.
If more Pa and/or more Ia and/or more Ea-k is necessary than ECC88 could stand, the noval dual triode ECC99 might be of interest.
Tom
If in doubt, just measure.
Old 17th April 2008, 10:28 AM   #9
oldeurope is offline oldeurope  Germany
Good moring,
I recommend the ECC83 12AX7.
Kind regards,
Darius
Old 17th April 2008, 11:01 AM   #10
Geek is offline Geek
Geek's Avatar
Totem pole an ECC88 into a White CF and drive nails.
This modified White CF (mWCF) has an output Z of 100 ohms
(though repeatedly with various brands, it's about 120 ohms)
You heard it last year at Dave's I believe (back porch).
Cheers!
Best/favorite CF NOS noval twin triode?Hide this!Advertise here!
question about twin triode tubes Nihilist Tubes / Valves 2 19th February 2009 05:39 AM
Biggest noval dual triode? leadbelly Tubes / Valves 10 6th December 2007 05:51 PM
Favorite noval hi gain dual triode? leadbelly Tubes / Valves 0 11th October 2007 11:28 PM
Any subs for 6N1 & 6N2 twin triode valves? rcavictim Tubes / Valves 39 20th April 2005 03:19 PM
Any Twin Power triode Noval type? john Tubes / Valves 8 6th April 2005 03:09 PM
