Grid bias with Class A SE ? - Page 2 - diyAudio
Old 20th April 2008, 03:01 PM   #11
Another disadvantage is that some high GM valves (mostly are valves designed for series regulation, as the 6C33C, 6AS7, 13E1) are better not to be operated with fixed bias, some datasheet even warn for this. Some solutions I have seen so far:
- bias compensation in this article from Borbely audio about a SE 6C33C http://www.borbelyaudio.com/eb396225.asp
(I think it would actually require some tweaking of the zener value)
- a fixed bias with servo. One possible implementation is given here: http://www.tubecad.com/2005/May/blog0046.htm More recently some micro controller versions appeared on the market, as here http://mennovanderveen.nl/eng/autobias.html
- Morgan Jones has a very ingenious solution presented in his Crystal Palace design. Some day I will copy it (I am gathering the parts...)
Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 20th April 2008, 05:01 PM   #12
Default Halbautomatische Vorspannungserzeugung
have a look at this old circuit link.
Comes from link.
Kind regards,
Darius
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 05:26 PM
Battery grid bias to fixed bias in Toccato? w00t Tubes / Valves 3 2nd December 2007 12:34 AM
CCS Grid Bias rdf Tubes / Valves 12 11th December 2006 05:26 AM
grid LED bias? fred76 Tubes / Valves 13 4th August 2006 12:00 AM
grid bias cuallito Tubes / Valves 2 19th April 2004 06:49 AM
Copyright ©1999-2017 diyAudio
