| diyAudio Sponsor | ||
Any opinions? I have two of the neat old Magnavox 86 chassis. One is restored with the feedback loop modified, the other has been gutted for restoration and I want to try the RH84 circuit in this one, if its worth it.
I'm gong to be creating a webpage as I go along for other DIY'ers to see how to restore/restomod these old amps as a budget Hi-fi system. I'm also open to CCS on the input or output stages, as well as possibly negative bias ( havent heard of it really in SE amps???) I want to keep pentode mode to keep the measly high power (triode connected doesn't give enough power at all for most normal efficiency speakers), so lets try and make a SE pentode amp sound as good as it can here.
always preach the gospel- and when necessary use words. |
#2 |
frugal-phile(tm)
One of my RH84s has Magnavox OPTs...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
How does it do on bass? smallish size obviously limits bandwidth...
#4 |
frugal-phile(tm)
The speakeers i use with it go to 70 Hz... it seems fine.
dave
#5 |
Any huge differences in sound or responce between the two?
#6 | |
frugal-phile(tm)
dave
#7 |
Are you sugguesting the magnavox transformers as parafeed chokes?
BTW, I am planning on wiring up this amp this week, but have experienced a major setback ![]() while cleaning the power transformer and prepping it for paint... I dropped it and caught it by the wires-several pulled out of the end bell. Darn it! No getting these transformers apart either, their heavily potted and you CAN NOT get the screws out of the transformer!! Don't even try! I've had this happen before and they snapped off and I ended up drillng them out- which was a pain in the butt! I just tossed the tranny. Sad. Know of any suitable replacements? The original voltages were 225-0-225 , 6.3v, 6.3v. The radio was rated at 90 watts , but I won't be drawing that much from it with just the amp. How much current do I really need on the HT side with two SE 6bq5's and one preamp tube?
#8 | |
frugal-phile(tm)
dave
#9 |
Thats kind of what I meant, but being so small and not having much inductance already, the magnavox OPT's probably would not make good PFC's would they? I do have four of them if it would,however, how does this affect the plate load, wouldn't it be halved since you're essentially paralelling them, or does the DC cap between the plate load and the OPT eliminate this resistance mismatch?
#10 |
frugal-phile(tm)
You aren't paralleling them. The small inductance will effect the bass roll-off thou. The Grundigs we used are about 13 H and with the 3.3 uF cap the bass starts rolling off in the 50 Hz neighborhood.
dave
| Rh84 Ptx | tim614 | Tubes / Valves | 17 | 10th August 2010 01:28 AM |
| RH84 based amp | vanofmonks | Tubes / Valves | 5 | 7th August 2009 02:19 PM |
| RH84 questions | kacernator | Tubes / Valves | 13 | 22nd April 2009 06:14 AM |
| 6FQ7 in RH84 | ThSpeakerDude88 | Tubes / Valves | 5 | 22nd December 2008 08:48 PM |
| Page generated in 0.09137 seconds (82.06% PHP - 17.94% MySQL) with 10 queries |
