diyAudio Sponsor
Old 15th April 2008, 11:09 PM   #1
kvk is offline kvk  United States
Default OPT impedance vs. speaker
suppose you have a SE amp with a 5K:8Ohm OPT. Now lets say you run that with 16ohm or 4ohm speakers. What does that do to the OPT impedance? Does it make it 2.5K or 10K respectively?
Old 15th April 2008, 11:16 PM   #2
tubewade's Avatar
Impedance is reflected straight through an output transformer. If the primary impedance is normally 5,000 ohms with an 8 ohm load it will be 10,000 ohms with a 16 ohm load and 2,500 ohms with a 4 ohm load.
Wade
Old 16th April 2008, 05:20 PM   #3
So what would then be the implications if one did run an 8ohm SE amp at 4Ohm or 16Ohm?
I would guess that there'd be less output at 16 Ohms?
At 4Ohms, I would guess there would be more output but also more distortion and more stress on the tube? If you were to just turn the volume a bit, would you still get acceptable performance?
Old 16th April 2008, 05:24 PM   #4
sorenj07's Avatar
2.5K SE is a reasonable impedance for some tubes, including 2A3's and 300B's.
Old 16th April 2008, 05:37 PM   #5
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Loudspeakers are not resistors. Just because a driver claims 4 Ohm impedance does not mean it is 4 Ohms from 20Hz to 20kHz. Far from it. Here's a typical 150mm "8 Ohm" driver. I use the 4 Ohm tap for everything.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Overall speaker impedance erob Multi-Way 5 19th January 2009 09:04 PM
Speaker Impedance PhilR Tubes / Valves 8 21st December 2003 06:23 PM
Speaker impedance not what it seems? annex666 Multi-Way 9 8th September 2003 12:13 AM
Speaker Impedance diyman Multi-Way 1 28th April 2003 06:24 AM
Speaker Impedance RobPhill33 Multi-Way 2 14th January 2003 07:55 PM
Page generated in 0.08385 seconds (70.60% PHP - 29.40% MySQL) with 11 queries
