| diyAudio Sponsor | ||
Interesting link to this Brazilian Amp.
http://www.enjoythemusic.com/magazin...audiopax88.htm It would be nice to hear some coments on this design. |
#2 |
Hi Apassgear!
Yes i would like to coment!!! But where is the schematic??.. Jorge |
#3 |
As far as I can make out it appears to be a SE KT88 amp with the output valve in some kind of new revolutionary triode configuration. However, as soon as they use phrases like "sonic aroma" to describe the output that annoys me for a start!
#4 |
Hi bournville!
Sonic aroma=coloration Jorge |
#5 |
Jorge,
Then why not say coloration? I just dislike the invention of phrases for the sake of some new jargon. Incidentally, I've got old radio service sheets from the 1930s which talk of coloration to describe audio characteristics - after 70 years isn't it time to move on to something more objective to measure audio quality and fidelity? |
#6 | |
Standard THD numbers are pretty meaningless. |
#7 | ||
-Hei!. i have a aromatic amp!...Hehehehheeh Quote:
The worst distortion (in my opinion) is the intermodulation distortion...and his sister de EMF induced intermodulation! Jorge Ps: Bournville im enjoying to change points of vue with you. |
#8 | ||
Well every amp gear has some sort of distortion. It's generaly accepted that distortion caused by the DHT is the most desiered of all if you have to have one. |
#9 | |
Jorge PS:as if it wasn't enough the cables break in! |
#10 | |
I agree Brett that the development of objective terms for measuring fidelity that would be universally accepted is nigh-on impossible - I think that I'm just irritated when terms are used with all the aplomb of a second-hand car salesman describing a car as a 'good runner.' There is also the suspicion that, as Tube_Dude says, terms like 'sonic aroma' can be used to bamboozle the innocent. |
| 40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? | dtm1962 | Solid State | 10 | 15th September 2011 08:38 PM |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Audiopax Model 7 | vizion | Tubes / Valves | 4 | 21st October 2007 06:53 PM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| power output calculations, rated power and required power output | metebalci | Tubes / Valves | 7 | 22nd February 2004 06:49 PM |
| Page generated in 0.10756 seconds (81.92% PHP - 18.08% MySQL) with 10 queries |
