screen-drive (g2 driven) plate curves spacing linear! - Page 3 - diyAudio
Old 24th June 2008, 06:45 PM   #21
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Hi Darius;
do you remember about amplification?
Without it we have simpler solutions, wit no any active elements at all.
The Devil is not so terrible as his math model is!
Old 24th June 2008, 09:36 PM   #22
Linearly spaced pentode curves? Sorry, no emulating the IGBT!
Besides: G1>Cathode resistance is a negative feedback.
You know the rules about feedback!
Old 25th June 2008, 07:51 AM   #23
Default #22
Originally #22 posted by kenpeter
Hello kenpeter,
please tell me the diyAudio feedback rules,
I am happy add them to the diyAudio technical forum rules, thanks.
Darius
Old 25th June 2008, 12:43 PM   #24
Ignore intrinsic negative feedback. Cathode resistance is evil.
No emulating anything, especially technical forum moderator.
Makebelieve sigline rules apply only to Darius.
Old 25th June 2008, 01:13 PM   #25
Old 25th June 2008, 04:05 PM   #26
Michael Koster's Avatar
Default #15 curve shapes
Output curve 1 shows a linear resistor.
Curve 2 shows a diode or a triode at negative grid voltages.
Curve 3 shows a pentode, tetrode etc., transistor FET BJT or a triode at
positive grid voltages.
Darius, I am a little confused by your hand-drawn plate curves.
You show both the "pentode" and "triode" curves converging at both ends of the resistor curve.
I'm more familiar with the attached curve which shows the plate curves asymptotically parallel with the "resistor" curve.
edit -- what I think the parallel plate curves show is relatively constant plate resistance for different grid voltages in the straight region of the curves, implying at least some of the triode-ness is retained at +ec1
This chart is for a 6F6 though. Maybe different tubes behave differently; I have not tested this myself.
Michael
PS
Old 25th June 2008, 04:24 PM   #27
smoking-amp's Avatar
Looks like a load line placed at right angles to the 6F6 plate curves would have fairly constant gain versus grid voltage around -10V to +10V on g1 (would have to deal with the grid current though). But this could be an illusion without some finer measurements. Two obvious counter effects of compression are occuring at larger + and - grid1 voltages, but they may just produce a peaked gain curve at the center (rather than flat), giving odd harmonic distortion.
Don
"I don't need facts, I'm smarter than you." - Hassockman Emperor: T_Bunk-um_un (Hanged 6 months later after announcing his latest health care plan would only cover burial expenses or a round of golf on his golf course.)
Old 26th June 2008, 06:43 AM   #28
Default #26
Originally #26 posted by Michael Koster
... Michael
PS
Hello Michael,
see attachment.
Kind regards,
Darius
Has anyone screen driven an EL84? Lingwendil Tubes / Valves 11 22nd April 2009 03:04 AM
Screen driven output stage nhuwar Tubes / Valves 2 1st December 2008 05:10 PM
6JN6 screen-drive (g2 driven) plate curves? GordonW Tubes / Valves 26 23rd April 2008 01:56 PM
15E and plate curves lochness Tubes / Valves 5 4th November 2007 03:41 AM
Copyright 1999-2017 diyAudio
