Grid choke as I/V?
Grid choke as I/V?
Old 8th April 2008, 07:05 PM   #1
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
Default Grid choke as I/V?
I have a DAC that uses a resistor (~200R) as the I/V. This resistor doubles as a grid leak and the signal is fed to the grid of a tube. Overall, this works surprisingly well.
But, it occurs to me that it might work better with a grid choke instead -- high Z, low DCR. Anyone have any thoughts? All of the grid chokes I have seen have much too high DCR, so I think it would need to be a custom part of some sort, or maybe just a low H hammond. Also, the particular DAC chip (AD1865N-K) has no DC on the Iout if that changes what will work well.
Attached is what I am thinking. If you replace the choke with a resistor, it is what I am currently using.
Old 8th April 2008, 07:44 PM   #2
DougL is offline DougL  United States
For a current output Dac, the load must have a much lower Z than the source.
An inductor has a very high Z, and would create extra distortion.
What I have seen people do is use a step up transformer to lower the effective load resistance while maintaining output.
I like the way you think. Keep at it.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Grid choke as I/V?Hide this!Advertise here!
Using a Grid Choke On the 2A3 when the input/driver is a Pentode? sgerus Tubes / Valves 4 18th March 2013 06:40 PM
Issues with grid choke phrarod Tubes / Valves 15 23rd August 2009 03:19 PM
Coupling caps size with grid choke? DHT112A Tubes / Valves 4 7th December 2006 06:22 PM
Could a filament transformer be used as a grid choke? Saurav Tubes / Valves 15 13th September 2003 01:18 PM
change to grid choke? Joel Tubes / Valves 2 5th December 2002 04:20 PM
