My Tabor Clone is finished.
Old 10th January 2011, 08:16 PM   #31
Tyimo is offline Tyimo  Hungary
Thanks!
What is your source? A CDP? Can it drive easy the input transformer?
Tyimo
Old 10th January 2011, 08:42 PM   #32
Shoog is offline Shoog
Shoog's Avatar
I use a single ended version of a Super Linear Cathode Follower as a preamp, so effectively a CF is the source. It has absolutely no issues driving the Toroidal phase splitter or the OEP's, and bass is in no way compromised. I think the reason is probably because the valve grids are such a slight load compared to the usual 600R input impedance these transformers are designed to cope with.
I would guess an anode follower might be a different question though.
Shoog
Old 10th January 2011, 08:56 PM   #33
Could you show me that Super Linear Cathode Follower preamp??
Old 10th January 2011, 09:04 PM   #34
Shoog's Avatar
Unfortunately the last version I built I never got around to drawing up an accurate schematic for it. It uses two ECF80's per channel. There is an input pentode strapped as a triode, the output Cathode follower is direct coupled and sits on a pentode CCS. On the top is a sense triode which keeps the voltage over the CF constant at all times.
It looks and sounds very like a Aikido, but is based on the Vacuum State FVP5.
One day I will circuit trace it and put it up on the web somewhere.
Shoog
Old 10th January 2011, 09:28 PM   #35
O.K. Thanks!
Old 12th February 2012, 04:40 PM   #36
av-trouvaille is offline av-trouvaille  Netherlands
Could someone please guide me how to implement the design in post 1 with the DHT 1624 instead of the indirect heated 807. I am aware this will complicate the power supply regarding the filament supply where the goal of Shoog was to simplify. For such a re-design at least the following should be adressed, I think:
- Integrate the ccs in the filament heater. As the filament voltage is only 2.5V hum does not need to be an issue. Otherwise, four separate DHT-filament regulators (each with their own filament tap) of the design of Rod Coleman or Guido Tent for the 1624 can be applied.
- Whether the B+ can be used as is or should be adapted depends on if the operation point of a 1624 is different from a 807. Apart from that I notice that Gary applies a higher voltage in his design for the 1624 on his site, although it is not easy to determine exactly because of the cumulating voltages that allow for dc-coupling. Can you please elaborate on this?
My Tabor Clone is finished.Hide this!Advertise here!
I Have Finished My Standel 25L15 Clone guitar88 Instruments and Amps 116 23rd September 2015 07:29 PM
The Clarro alias Totem Arro Clone. Finished!! FrankDIY Multi-Way 26 9th February 2010 04:47 AM
Solid State Tabor Amp jkeny Solid State 11 25th June 2008 11:24 PM
my finally finished gain clone (the whole story) loudlemmy Chip Amps 0 1st April 2005 06:00 PM
Question regarding ProAc 2.5 Clone and Tempo 2 Clone zoooh Multi-Way 5 11th March 2003 09:19 PM
Copyright ©1999-2017 diyAudio
