Old 8th January 2011, 09:15 PM   #21
Tyimo is online now Tyimo  Hungary
Thanks Shoog!
I will try it with step down 2:1+1.
Few more questions:
- What VA rating do you sugest? 20-30Va?
- What voltages? 110Vac: 55Vac+55Vac?
- What is that OEP? "I used microphone transformers from OEP for phase splitting."
Tyimo
Old 8th January 2011, 10:48 PM   #22
Shoog's Avatar
The lowest VA should give you the highest inductance. I found it difficult to get anything less than about 50VA in 110:55+55
OEP are this manufacturer;
OEP
I got mine through Farnell.
Hope that helps
Shoog
Old 9th January 2011, 12:18 AM   #23
What did you use for ccs?
Old 9th January 2011, 08:10 AM   #24
Thanks Shoog!
I am trying to build a Tabor clone with EL82.
Could you give me some suggestions?
Tyimo
Old 9th January 2011, 09:32 AM   #25
Sorry. I typed wrong.
I mean with EL84 tube.
Old 9th January 2011, 12:05 PM   #26
Shoog's Avatar
I used IXY900 chips in the Tabor. I had real issues finding a CCS which was stable enough to withstand the power up spikes - the IXY900 was the only one which has been reliable. I have no zeners for protection in this one, but using zeners across the CCS should help.
In the latest project which is update to the DC7 6080 amp I built, and which is based on the Tabor concept, I used a version of the LM317 with a voltage rating of 125V, this has worked flawlessly. I included 120V Zeners across them for protection.
I can only really point you to my schematic for hints. The real issue with the Tabor is its relatively complex stacked power supply. I avoided this by using a +/- power supply off the single power transformer and hanging the front end off of the negative rail. All the usual complexities of this (ie biasing up the front end using voltage dividers and caps) is avoided by using the input transformer which is biased down to the grid voltage of the drivers. In the DC7 version I even managed to arrange the voltages such that the screens of the driver pentode were at 0V (effectively about +180V) which avoided the need for a seperate screen supply.
I have included the schematics of the DC7 Mk II because they represent the ultimate refinement of what I have worked on for the last 7yrs or so. Its quite simple but there are many hidden tricks. This would be a good one to attempt to copy or as a conceptual starting point.
Shoog
Old 9th January 2011, 04:39 PM   #27
Thanks for the info!
Tyimo
Old 9th January 2011, 06:42 PM   #28
And if you cross couple the ADJ to halfpoint of opposite sense resistor?
Blumlein garter style....
Remembering that both anodes are capacitor coupled and share the
same voltage swing.... I don't think blocking impedance is reduced,
but you might get better matching DC.
Old 10th January 2011, 06:02 AM   #29
Hi Shoog!
Is this OPE transformer a 600R:600R line input transformer?
Could you tell me how much indcutance has it?
Tyimo
Old 10th January 2011, 03:32 PM   #30
Shoog's Avatar
This is the datasheet of the one I used. I have no other details.
Shoog
I Have Finished My Standell 25L15 Clone guitar88 Instruments and Amps 114 22nd May 2012 04:22 PM
The Clarro alias Totem Arro Clone. Finished!! FrankDIY Multi-Way 26 9th February 2010 03:47 AM
Solid State Tabor Amp jkeny Solid State 11 25th June 2008 10:24 PM
my finally finished gain clone (the whole story) loudlemmy Chip Amps 0 1st April 2005 05:00 PM
Question regarding ProAc 2.5 Clone and Tempo 2 Clone zoooh Multi-Way 5 11th March 2003 08:19 PM
Copyright ©1999-2013 diyAudio
