| diyAudio Sponsor | ||
I'd like to use a couple of IXYS 10m45s as a current sink for 6sl7 LTP (6V6 PP amp). Is there any mistakes or improvements in the schematic below ? Thanks in advance, George |
#2 |
I have used exactly the same circuit with good results. With -24 volts the IXYS chip works good. A slight improvement may be noted with much higher voltages.
If you have less voltage and only need 10mA, check out the National LM334. I have used that one with a - 7 volt supply (rectified 6.3 V). It is only good to 40 volts max, 10 mA max.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#3 |
Has anybody used the 1N5283-1N5314 current regulator diode range? I use a 3.9mA and a 4.3mA parallel, supplied from the -50V bias voltage and they work fine.
#4 |
You'll get better performance if you cascode two of them....
#5 |
On second look: Only 2 mA... Performance may be marginal with the IXYS chip. Try the 2 transistor LED-biased CCS in the Baby Huey thread.
#6 | |
#7 |
Go to www.national.com and insert LM334 into the search box. The product page will show up. There are two circuits shown, you want the simple one on the right. Yeah, just a resistor and the chip. For 8 mA the resistor will be about 10 ohms. Connect the bottom terminal (V-) to your negative voltage source. and the top terminal (V+) to the 12AV7 cathodes. This chip will function with less than a volt so you may get by without a negative voltage (ground the V- terminal) although I have found that the chip likes some headroom. Rectified 6.3V is fine. Don't use over -35 volts.
Morgan Jones uses this chip in some of his designs and it is mentioned in the third edition but I am not at home now, so I don't know the page numbers. http://www.national.com/mpf/LM/LM334.html
#8 |
Couldn't be more simple. Thanks! I'll post pics when she's done.
Wait a minute. Do you think I could get by with leaving the center-tap on 6.3V grounded, and just full-wave rectifying the 3.15-0-3.15V (more like 3.3-0-3.3V) to get around -4.5V? |
| 10m45s LTspice model | dave slagle | Tubes / Valves | 10 | 19th October 2011 04:37 PM |
| IXYS 10M45S current regulators, qty. 36 | zigzagflux | Swap Meet | 2 | 10th May 2009 12:58 PM |
| Help needed with 10M45S integration . | TugaTweaker | Tubes / Valves | 11 | 9th March 2009 07:33 PM |
| Wtb; 10m45s | Cobra2 | Swap Meet | 9 | 26th November 2008 05:17 AM |
| Opinions on Ixys Fred rectifier in amplifiers? | imperfectcircle | Solid State | 12 | 11th May 2007 08:34 AM |
| Page generated in 0.08442 seconds (83.30% PHP - 16.70% MySQL) with 11 queries |
