diyAudio Sponsor
Old 4th April 2008, 12:40 AM   #1
Default 5718 subminiture tube?
Is the 5718 tube good for anything or should I throw it in the trash?
Old 4th April 2008, 12:57 AM   #2
Sheldon is offline Sheldon  United States
Fairly nice plate curves. Could be used as a preamp tube, or even a little PP headphone amp.
Sheldon
Old 4th April 2008, 01:30 AM   #3
tubelab.com's Avatar
I have a few hundred of them, so sooner or later I will find something to do with them. They can be stuffed into an 8 pin round (to-5 style) op-amp IC socket so that you can change tubes.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 4th April 2008, 06:50 AM   #4
coresta is offline coresta  France
coresta's Avatar
the brother is the 5719 , high mu (70) ... i have many too! would you play a swap George ?
Old 4th April 2008, 01:18 PM   #5
Maybe. I an thinking about building a vacuum tube guitar preamp right into the guitar, so a high mu tube may be useful. I have a box with about 500 assorted sub mini tubes I will check what is in the box when I get home. I know that there are some pentodes, and dual triodes but I don't remember any numbers right now.
Old 4th April 2008, 02:23 PM   #6
JoshK is offline JoshK  United States
I was thinking that submini's would make nice tubes for phono preamps and output stages of CD players.
Old 4th April 2008, 04:46 PM   #7
coresta's Avatar
have some on e.b. for sale under # 250231095718
Old 4th April 2008, 05:49 PM   #8
7n7is's Avatar
Scroll down to 5718
http://www.machmat.com/sales/2-5.htm
Old 4th April 2008, 05:58 PM   #9
7n7is's Avatar
Its used here.
A Rapid Scanning Spectrometer for Oscillographic Presentation in ...
cell. The cathode follower employs a Sylvania 5718. subminiature triode and is shown in Fig. B. The. intermediate amplifier is shown in Fig. 5C and is made ...
http://www.opticsinfobase.org/viewme...id=50074&seq=0
http://ephysics.fileave.com/spectros...Rspec-5718.pdf
Old 4th April 2008, 06:49 PM   #10
7n7is's Avatar
Subminiature tubes are discussed in this book. Click the links in Contents to get to the pages on miniaturization and subminiature tubes.
Advances in Electronics, Vol. III L. MARTON,
http://books.google.com/books?id=PHx...ZdgQ#PPA184,M1
5718 Nuvistor ? exurbia Tubes / Valves 4 1st June 2009 04:16 PM
Another 3f4 spice triode model: 5718 submini triode wa2ise Tubes / Valves 0 5th September 2008 04:31 AM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 01:19 AM
Page generated in 0.09677 seconds (76.20% PHP - 23.80% MySQL) with 10 queries
