| diyAudio Sponsor | ||
#11 |
why would you put it in paralell with the tube? wouldn't that short the AC line out and cause the diode to e'splode?
always preach the gospel- and when necessary use words. |
#12 |
No, the capacitor is still in series, limiting the current. On one half-cycle, the diode conducts, and the capacitor charges. On the other half-cycle, the diode is reverse-biased, ands the capacitor discharges through the gas tube.
A surge on the power line COLUD zap the diode, so a current limiting resistor is a good idea. Of course if the diode shorts, the worst that will happen is that the bulb goes out - the capacitor still limits the current. |
#13 |
#14 |
Yes, that's what I tried. A resistor in series with the .47 cap is recommended. Either polarity worked for the diode - the glow concentrates at the negative termnal.
Of course the capacitor alone is simplest. |
#15 |
a diode and a resistor isnt much more to add to it..
The AC buzz of the tube does get a little annoying so yeah.. Any way to make it brighter btw? Is the glow only on the inside of the plate or can it be on the outside too?
#16 |
Did you read the article I posted?
Gavin |
#17 |
like I said, a series resistor and a series diode are all that are needed.
| My Zen-Light | skidave | Pass Labs | 6 | 21st September 2007 11:08 AM |
| Page generated in 0.07649 seconds (74.83% PHP - 25.17% MySQL) with 11 queries |
