| diyAudio Sponsor | ||
#31 |
I am using solid core copper wire, a bit more thick than cat5 in all connections to the volume pot. I find it very difficult to solder, as the solder seems to not wet properly the surface of the wire. So I plan to change it. What kind of wire do you use?
Miguel |
#32 | |
Jorge |
#33 |
I will try to put there something thinner. I am worried about contact between solder and copper. Maybe my 25W iron is not enough...
Miguel |
#34 |
Hello Miguel,
EF86 can be uninviting when it comes to layout. I know the problem you’re talking about and I can believe you don’t have ground loops and still have a hum. There are some tricky things there I did not figure. If you had a solution it is maybe best to go back to that. If you’re ready for experiments, try to wire shield (pins 2 and 7) in different ways. And take note at the changes when you move resistors physically. Anyway, this tube can work in given configuration without any hum, and without series resistor at the input. As I said already, I did not figure this story, but have one (PCB) solution that surely works. Send me an e-mail if you are interested for more info about it. Pedja |
#35 |
Hi Pedja,
Thanks for your help but I don´t want to go into making pcb's ... I have everything p2p wired, with the tube bases bolted to chassis. The layout is quite nice now, as the circuit is simple. I will try to move things a bit inside to see what happens and do something with the shield pins Miguel |
| hum on pre-amp when volume is turned up | phrarod | Tubes / Valves | 6 | 14th June 2009 06:11 PM |
| Turned up the volume and now its fooked | gifted jones | Solid State | 4 | 17th December 2008 09:51 PM |
| Pop when amp is turned off | boostin1989 | Solid State | 6 | 10th October 2006 04:10 PM |
| Music plays after amp is turned off. | Killjoy99 | Solid State | 29 | 10th January 2005 06:32 AM |
| Leach amp has hum only when turned off! | kiwi_abroad | Solid State | 12 | 26th March 2004 03:17 PM |
| Page generated in 0.07727 seconds (71.57% PHP - 28.43% MySQL) with 11 queries |
