| diyAudio Sponsor | ||
Hi tubeholics
#2 |
The data sheet say that both the 5U4 and the 5R4 are only food with 4uf of first stage capacitance. I had one die on me the other day because I overloaded it. They are both good to about 240mA which should cover almost all 807 designs.
Shoog |
#3 |
ok Shoog, thanks for reply ! I said 10uF for two valves . But do you mean a twin rectifying will improve sonics ? regards Pierre
#4 |
If your proposing to use two 5U4's per monoblock, I can't really see any reason why it would improve sonics. Also it may not be adequate protection against overloading as one may hog current as they age. If you need more than 240mA then go look for another rectifier.
Shoog |
#5 |
I have recently been testing a design using 450-0-450v 230mA transformer into a 5R4=>11uF=>17H=>500uF(excessive!) and i get about 520V on the anodes of the 807's in AB. Seems to work well, although im a bit scared about the 11uF cap now i read Shoogs' comment. |
#6 |
yes , 4uF is a maximum/nominal value for the 5R4 . Then, 10Hy then 40 to 100 uF is perfect . Whats the idle current of your 807 at 0watts ? do you regulate screen voltage (max300v) or do you have another psu ? Pierre
#7 |
You could use two damper diodes. Svetlana makes some nice ones that sound very good. I think damper diodes tend to sound better than 5R4s
#8 |
diyAudio Moderator Emeritus
I agree about the dampers. Svetlana's 6D22S can use up to 50uF with a C inout filter.
| For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! | opc | Swap Meet | 23 | 2nd November 2009 05:04 PM |
| Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest | mbcouple | Swap Meet | 2 | 27th October 2008 10:27 PM |
| Testing 350B with B & K 747A | GRIDFIVE | Tubes / Valves | 1 | 12th March 2008 08:20 PM |
| SMPS for diy audio amps and multi-channel diy amps (and their power supplies) | tlparker | Solid State | 18 | 31st August 2006 10:39 AM |
| Page generated in 0.09272 seconds (76.12% PHP - 23.88% MySQL) with 10 queries |
