| diyAudio Sponsor | ||
#81 | |
It's just your stereophile boiler plate sentence. Never search for meaning in such things. It kind of disappointed me as well. Frank do we REALLY need 4 enclosures for this thing? Could we condense while keeping separate gnds? |
#82 | |
I think he simply meant that:
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#83 | |
diyAudio Senior Member
I actually built it in two cases, one for the PSU and another for the preamp proper. Dimensions: 16" * 11" * 3" ( Just to give you an idea about what you need if you'd add the phono stage as well.If you don't need that half the width should do.) Starground is for anything PSU related is inside the PSU chassis, everything signal related is starground inside preamp chassis. Grataku, Since you prefer measurements: Specifications Line preamp: Powerconsumption: 40W. Weight 2 Kgs. preamp and 3.5 kgs for the PSU. Sensitivity (IHF 0.5V) Line: 525mV into 100K. THD Typically better than 0.05%. Frequency Response: 10Hz - 200KHz. +/- 0.2dB. Noise: better than -90dB. Input overload: Infinite. Maximum Output level: 45V Output Impedance: 47 Ohm. Stereo Separation: better than 100dB at 1KHz. Feeling better now ? Peter, I knew you'd bring that up. Cheers,
Frank |
#84 |
#85 |
This uses yet another PSU, both are identical to the line peamp though. Cheers, P.S. Dave, redraw to your hearts content...
Frank |
#86 |
This circuit mates to the previously posted phono stage: This stage is a candidate for improvement, any suggestions welcomed:
Frank |
#87 | |
frugal-phile(tm)
I note this uses an ECC83 class tube. I wonder how close it is to the RCA one? dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#88 | |
frugal-phile(tm)
dave
#89 |
Hi Frank
Interesting phono. One of the few (i only know of the 834) where all the gain comes from the first stage and all the correction - from the second. How would you describe its sound compared to more traditional topologies like fully passive or 2 stage with an overall feedback. Not that i've tried many, but to me the split passive RIAA has always ruled in both vacuum and sand implemetation. I should try something different though Your pre-pre can certainly benefit from battery plate supply and something better at the heaters too. cheers peter |
#90 | |
Anyway, I was just teasing you a little. The RCA diagram you posted should sound very good too, it reminds me of the first phono preamp Jadis made. Any idea what the number of the RCA manual is? I've two different ones and none sport the cct you posted. Cheers,
Frank |
| FRANK"S 6SN7 preamp/linestage | mosfets | Tubes / Valves | 88 | 16th February 2012 01:09 AM |
| Frank's Tube Database Down? | kevinkr | Tubes / Valves | 6 | 16th October 2008 09:57 PM |
| Regulated PowerSupply for Frank's 6SN7 Preamp | Vidi | Tubes / Valves | 2 | 10th December 2006 12:23 AM |
| Frank Philipse's tube site | Sheldon | Tubes / Valves | 4 | 3rd November 2006 02:44 PM |
| Page generated in 0.10912 seconds (80.77% PHP - 19.23% MySQL) with 11 queries |
