| diyAudio Sponsor | ||
#21 |
My apologies Frank. I didn't know that a circuit topology had already been decided on. Maybe one day I'll build that 6AS7G single stage buffer just for kicks. I'm following this conversation with great interest. Have you decided on a tube regulated supply?
or IC regulated? DC on the heaters? Just curious. G
Gavin |
#22 | |
diyAudio Senior Member
Everyone is welcome to contribute in any way they want, your idea is worthy of consideration to say the least. Tony, Don't expect a chicken before the egg.
Frank |
#23 | |
Just putting some spice. I'm most probably be building what eventualy will evolve from this thread.
#24 | |
You could rectify with tubes too, just change the specs for the powerxformer accordingly + it may require a self to achieve decent filtering. Anything prior to the reg will be a decent electrolytic cap, after the reg I recommend a film cap. I hope to have everything ready before the end of the week, my only concern is now that the input impedance (1Meg.) may be too high for a CDP. If anyone has concerns about this, please let me know. It is nothing crucial but the attenuator series values and the shunt will need to be changed accordingly then. The gridleak on the 12BH7A is 1Meg and I like to keep that value constant for the attenuator not to be compromised, its' value could lowered though. Cheers,
Frank |
#25 | |
What does a 1 Meg Input impedance means in terms of using a 50K attenuator? Would a 50K att be to low? Why? |
#26 | |
Of course in a oposite case...you have a problem! Jorge |
#27 | |
Hi guys,
The reason I asked about the high input impedance was that with some highly capacitive cables it may cause a HF roll-off. Quote:
The idea is to use a 1Meg attenuator where the gridleakresistor would be 1Meg too. So we would have only a series R that would be switched over 23 usable positions, the gridleak would be held constant. A ladder attenuator built like this is ideal since it does not affect the load on the tube in any way. Cheers,
Frank |
#28 | |
Jorge |
#29 | |
I am just trying to cater for as much product out there as possible. If you guys say that it's no problem, then fine. Cheers,
Frank |
#30 | |
So this will mean that we would have to use high value series resistances? say >1 Meg? |
| FRANK"S 6SN7 preamp/linestage | mosfets | Tubes / Valves | 88 | 16th February 2012 01:09 AM |
| Frank's Tube Database Down? | kevinkr | Tubes / Valves | 6 | 16th October 2008 09:57 PM |
| Regulated PowerSupply for Frank's 6SN7 Preamp | Vidi | Tubes / Valves | 2 | 10th December 2006 12:23 AM |
| Frank Philipse's tube site | Sheldon | Tubes / Valves | 4 | 3rd November 2006 02:44 PM |
| Page generated in 0.10715 seconds (77.59% PHP - 22.41% MySQL) with 12 queries |
