| diyAudio Sponsor | ||
Hi
Can any recommend links for things like nice amp chassis, control knobs, front panels and other bits and bobs? Im trying to get ideas of how to plan out the look of my diy amp project Thanks for the suggestions Al |
#2 |
Heres some photos to get you started.
Not exactly a scratch build, but an Asymetrical approach to a nice looking stereo SE amp that was made with what I had to work with from an old Magnavox. Here is my own chassis design for a Dynaco ST35 clone. I used a hammond 12x10x2 aluminum chassis and polished it using metal polish available at Lowes hardware. I used cheap 1x2 oak craft strips from Lowes for the casing at a total cost of $3.50. The control knobs for both are $1.75 at radio shack, and look quite professional and "hifi" IMHO. I like to do things on a budjet, so thats my take on things. Hope you're inspired! http://getchellaudio.googlepages.com/IMG_0349.JPG
always preach the gospel- and when necessary use words. |
#3 |
That's aluminum?!! Got the name of that polish? Got no Lowes near me but maybe I can get polish at a similar store. Very nice work, SpeakerDude. Boutique looks on a budget - I love it.
#4 |
Try your local auto parts store for a product called "FLITZ" it'll put a shine on a turd !!
#5 |
love the coat of arms on that transformer!nice work thanks
#6 |
Sand progressively from 80 thru 900 grit: 80, 120, 220, 350, 400, 600, 900. Finish with a buffing wheel and a can of Brasso or silver polish.
#7 | |
Gavin |
#8 |
Have a look at the stuff that VT4C is selling. There are knobs, chassis and "collars" (or plates) that are attached to the tube sockets. You will also fine nice retry type meters.
Go for a solid wood chassis of beech or birch or oak. Use some kind of oil and work hard to get a nice surface.
/Magnus
#9 | |
#10 |
http://www.charlestonarea.com/octane...g_compound.jpg
there is the stuff I used, I don't know if theres a name brand but it is made in the USA. You can find it in the tool section of Lowes. I only used the high gloss stuff so it took a while to polish it up. Its basically a claybar that removes aluminum and smooths it out while polishing at the same time. Messy and you must use a buffer or drill with a small buffing wheel. Thanks dubdub, that was the magnavox shield off of the radio that the amp came out of. Thought it gave it that "botique-im some-high-falutin'-fancy-brand-transformer" type of look ![]() FWIW, the transformers are made by Stancor as indicated by the 138 IEA code on them.
| CDPRO2 Group Project (open source project) | BrianGT | Digital Source | 147 | 8th August 2008 11:37 AM |
| My OLD Project....... cheap tube audio project!!! | tube-lover | Tubes / Valves | 4 | 8th May 2008 09:26 PM |
| New OB project | Geoff H | Full Range | 18 | 16th September 2007 11:14 AM |
| My first project, cool project. | sorinsistem | Solid State | 3 | 19th January 2006 05:08 PM |
| Page generated in 0.08909 seconds (86.11% PHP - 13.89% MySQL) with 11 queries |
