GU-50, GM70 and KT88
Old 24th September 2012, 03:53 PM   #41
palmas is offline palmas  Portugal
Originally Posted by Wavebourn View Post
450V B+, 510 Ohm 10W cathode bias resistor shunted by 50 uF 100V capacitor; 2K 100 MA OT; 100 Ohm screen grid stopper connected to anode; G3 connected to cathode; 220K grid leak resistor to the ground (may be higher due to autobias).
That's it.
Can you draw it now?
Thanks, for the suggestion, it'll be a good starting point for tryal of my PSE.
Will also try 480V and 45mA per tube.
You prefer the GU50 with self bias over fixed bias?
Old 24th September 2012, 05:43 PM   #42
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I mean single ended. Self bias means negative feedback by DC current, so you don't need to measure and adjust bias. The tube will do it for you. However, for parallel SE it would be better to have the way to adjust bias for each tube, but anyway it is better to select tubes for parallel operation.
The Devil is not so terrible as his math model is!
Old 25th September 2012, 02:26 PM   #43
I'm aware of what it is, but having to decide and as in my experience most tubes sound better with fixed bias, I was wondering about your suggestion.
Even with fixed bias I always add a bit of "self bias", even if it is just to measure current and stabilise the DC part.
When in parallel it is usefull to be able to adjust bias independent for each tube, as it gives more latitude on pairing the tubes.
If you have some experience on using the GU50, I'd like to profit from it, as I'm building a PSE with 2xGU50 into a LL1620/90.
PSU is about 480V (I can reduce it replacing the rectifier tube or using some stabilising circuit). I think 480V is too much for triode GU50 and to little for pentode, but as I will only be using each tube at 45mA, the grid current will not aproach the limit of 5mA. Can you help me on this?
Old 26th September 2012, 05:06 PM   #44
torrence is offline torrence  United States
torrence's Avatar
Hi Wavebourn,
I have been playing with GU50 Triode curves for a while now, and it really looks like a 3.5k-5k transformer gives better power output with lower distortion, especially sitting at a quiescent point around 80mA at 400V. I have noticed in these forums that you typically advocate for something lower, more like 2k. What is pushing you in this direction?
A good example is attached (not my work, swiped from here).
Old 27th September 2012, 06:14 PM   #45
Wavebourn's Avatar
I don't remember when I pushed toward 2k. Probably 2k5 for 300V B+ and 45W dissipation Anode+G2?
Edit: also if you add positive voltage on G2 curves shift left. I used +12V that I had from filament rectifier.
Old 14th April 2016, 11:51 AM   #46
ahuramazda is offline ahuramazda
Originally Posted by feralmeida View Post
One might use zener diode string with sufficient wattage to drop the voltages below 300 volts. Same as but lower dc, You may even use gas regulator tubes.
Old 30th December 2016, 04:31 AM   #47
oltos is offline oltos  United States
Default KT88, GM70, GU50. Which sounds & drives Quad ESL 57 best?
in my experience most tubes sound better with fixed bias, I was wondering about your suggestion..... Can you help me on this?
I'm a newbie with limited amplifier design knowledge. Please advise so I don't buy or have built the wrong amp for these speakers with the crazy impedance curve! Quad ESL & ESL63 Information
Old 30th December 2016, 05:59 AM   #48
While one can’t have tea without boiling water, which of the best sounding of these (or other?) tubes to drive the Quad 57 ESLs can be used in a 30 to 35 wpc amp that would have the smallest power draw, and thus emit the least amount of heat?
Old 14th February 2017, 03:28 AM   #49
Wavebourn's Avatar
Does the speaker expect electrical damping, or sounds better with higher output impedance of the amp? I am not familiar with this speakers. Also, which tube matters less than which topology you prefer. GU-50 I would use in P-P topology; GM70 would be good for SE in A2, while KT-88 and other 6L6-likes I would prefer to see in guitar amps.
Edit: I went to the link and found that a pair of EL84 is indeed the right choice to drive this speakers. Even don't think of a "Zero feedback" fashion, with zero feedback it would sound like a crap!
Old 14th February 2017, 07:52 PM   #50
payloadde is offline payloadde  Europe
payloadde's Avatar
Should read " if you add positive voltage on G3 (suppressor) curves shift left", I presume.
How far do curves shift under +12v G3-bias ? what is the transconductance of G3 in a GU50 ?
and how much current is to be expected into G3 ... or is it out from G3 ... ?
Talking about G3, I wonder whether G3 can be used to adjust for symmetric bias currents; e.g. amp with 2xGU50 in PP, cathode bias, single common cathode resistor;
if tubes don't match very well, individual G3 voltage adjustment could be used to balance DC currents in the OPT ... doable ?
Judge: This court appreciates that you invented physics, Mr.Newton, but unfortunately you can't have a patent on it.
GU-50, GM70 and KT88Hide this!Advertise here!
want to do PP-GM70 day Tubes / Valves 79 10th October 2011 07:30 PM
GM70 sockets? otto88 Tubes / Valves 41 7th September 2009 10:08 AM
GM70/GM70 parafeed SET? louischia Tubes / Valves 10 4th December 2008 04:12 PM
any example of SE designs using GM70? jarthel Tubes / Valves 3 31st May 2007 09:10 AM
Another Gm70 amp !! HFGuy Tubes / Valves 4 8th July 2005 09:41 PM
