GU-50, GM70 and KT88 - Page 2 - diyAudio
Old 30th March 2008, 09:44 PM   #11
Tweeker is offline Tweeker  United States
The curves Ive seen on datasheets were indeed slightly different. The LS50 took a little more bias to run at 80ma 400V than did the GU50. YMMV. Possibly idealized curves on a datasheet are not necessarily the same as curves from the actual samples you are using.
Be sure your foil hat has a good low impedance ground.
Old 31st March 2008, 07:37 AM   #12
soundbrigade's Avatar
Send a message via MSN to soundbrigade
Here you have some DATA
For the REAL GU50.
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 31st March 2008, 08:38 AM   #13
Thats the one. Thanks for link.
Old 31st March 2008, 08:43 AM   #14
It's written in Russian, but I guess you can read the graph (where 'B' means 'V' like in Volt - 'BAX' means btw Volt/Ampere-Characteristics).
If somethings unclear - contact me!
/Magnus
Old 5th April 2008, 05:44 PM   #15
pwan is offline pwan  United Kingdom
Sorry, A bit off the topic
Any one know if the OPT for KT88 can be directly used as OPT for GU-50 ( both SE and PP)? Thanks.
Old 5th April 2008, 05:51 PM   #16
I have run GU50 on 5K anode load. That's my kind of answer.
Two gu50 in parallell shoudl be 2K5.
/Magnus
Old 5th April 2008, 05:57 PM   #17
I guess you means 5K "Push Pull" OPT?
Old 5th April 2008, 06:46 PM   #18
Meant SE. Have maybe some images I can share - tomorrow.
/Magnus
Old 19th June 2010, 05:42 PM   #19
Send a message via MSN to feralmeida Send a message via Yahoo to feralmeida
..... and conected g2 and g3 to anode?
Мощный однотактный усилитель на ГУ-50 - HiFiNews.RU
Old 19th June 2010, 07:31 PM   #20
Nope!
Much notice must be paid to the fact that g2 doesn't take more than approx. 250V.
/Magnus
want to do PP-GM70 day Tubes / Valves 79 10th October 2011 06:30 PM
GM70 sockets? otto88 Tubes / Valves 41 7th September 2009 09:08 AM
GM70/GM70 parafeed SET? louischia Tubes / Valves 10 4th December 2008 03:12 PM
any example of SE designs using GM70? jarthel Tubes / Valves 3 31st May 2007 08:10 AM
Another Gm70 amp !! HFGuy Tubes / Valves 4 8th July 2005 08:41 PM
Copyright ©1999-2017 diyAudio
