| diyAudio Sponsor | ||
hello!
I'm in the middle of designing a preamplifier circuit on multisim to go in an stomp box for bass guitar. I have two OPA627AM op-amps for the peak/notch part of my circuit but I was hoping to replace them with thermionic valves. I have two 12AX7 valves that I've noticed have a pair of triodes inside. Can I use one of these valves to replace both of my op-amps? If so tell me how! and, if not, do I need a different type of vlave to do the job? I was initially gonna keep the valves for a 'drive section of the pedal but I haven't figured out how to do that yet. Any advice on perhaps using the valves as an intentional overdrive at a stage after the preamp section (and keeping the op-amps in the preamp stage as they're of rather high quality anyway) would be appreciated too! Thanks! :-) Jenks. |
#2 | |
U1 is just a simple unity gain buffer. A cathode follower could replace it easily enough. As for U2, you treat the grid as the (-) inverting input, and the cathode as the (+) non-inverting input. All these op-amp based filters were originated back in the 1940s with VT implementations in mind. Of course, the 12AX7 won't have the open loop gain of the op-amp, and so will probably require component tweaking in order to get similar performance. That schemo looks perfectly serviceable. If it's VT-type distortion you're after, an over driven VT stage after that will do it. |
#3 |
Hi Miles!
Thanks for your reply! Yes, I've had a little read and it definitely makes a lot more sense to include my 12AX7's in a seperate overdrive stage, after the tone shaping controls. I've been looking at a few circuits this morning (which I've attached) I'm intending on using this pedal as my overdriven sound, as i have the MXR blowtorch for all-out distortion/fuzz so I was thinking to try using the 'soft-clipping' circuit. I'd love to try the MXR one too but I've no idea how it manipulates the signal so I'm tempted to leave it alone until I'm a bit more experienced on this topic! Any advice on how to best utilise the valves I have for achieving a rich & warm tube overdrive sound in my pedal will be greatly appreciated! thanks again. Jenks. |
| Replacing NE5532 Op-Amps with AD827? | KevinLee | Solid State | 5 | 12th June 2010 05:24 AM |
| Help replacing TL072CN op amps for TLE2072CP | SoundSpot | Solid State | 4 | 23rd December 2008 11:31 AM |
| Replacing Valves Leak Stereo 20 | pubrunner2000 | Tubes / Valves | 6 | 15th December 2007 01:01 AM |
| replacing op-amps in mixer | DoomPixie | Parts | 8 | 20th October 2005 04:43 PM |
| Replacing Valves | Tom Smithson | Tubes / Valves | 1 | 19th October 2004 02:20 AM |
| Page generated in 0.08277 seconds (71.53% PHP - 28.47% MySQL) with 11 queries |
