6S19 Circlotron (OTL)
Old 29th July 2008, 06:14 PM   #41
revintage is offline revintage
R13/14 0 ohms: More feedback if you happen to like it.
Zout below 2ohm(but not more power into low impedances), lower sensitivity.
Iq 50-60mA: Class AB, same power. Class A up to 1W.
Old 29th July 2008, 06:33 PM   #42
Fuling is offline Fuling  Sweden
Adjustable feedback (a two pole switch shunting R13/14) can be useful when using the amp with different speakers. Ive noticed that some speakers sound better with lower damping factor.
Re. Iq I thought the output power would rise a bit due to bigger "current headroom" with lower Iq. The tubes will probably last longer at 60mA, listening tests might tell if its worth it
PS: For a while I was a bit confused about the relatively high gain, but with R13/14 in place it makes sense. Without them the output stage gain must be slightly lower than unity.
Old 29th July 2008, 07:25 PM   #43
Youre absolutely right about more power with lower Iq. But it is so marginal and not worth mentioning.
Adjustable damping is absolutely a good thing!
Probably the amp will sound better the higher standing current you run through it, at the expense of shorter tube-life. So go for high Iq and better sound as long as they last.
Also note, I was to lazy to draw gridstoppers for the output tubes and on the MOSFET. Maybe one should also add a small resistor on each anode for current monitoring. Some kind of bias adjustment is also needed. I changed it by varying the neg.-supply.
Old 29th July 2008, 07:50 PM   #44
Well, if I was in need of high output power I wouldnt build an OTL with eight tiny output tubes anyway!
I could wish for a little more voltage from the floating power supplies (120VDC would be nice) but Im stuck with the transformers I have and there is no room to add turns to the secondary windings.
As usual Im trying to get the best out of whatever parts I can find in my junkboxes or buy cheap used or as surplus.
If this was a no compromise, cost-no-object project Id use at least twice as many output tubes, custom wound transformers with multiple taps for finetuning the voltages and linear 12VDC power supplies for the heaters.
What I do have is a fairly large stash oh output tubes, so running them a bit hot is definitely not out of the question!
Regarding grid stoppers Im using 33k on each output tube.
Better safe than sorry! IIRC Bernt J uses 110k in his PL519 OTL.
Ive also put a 2,2R 3W resistor on each cathode for current sharing and monitoring.
Except for the semi-ruined paint job this project has gone well so far. Im done wiring up the output tube heaters and all the grid stoppers, cathode resistors and plate connections.
Must order some caps and resistors before I can finish the signal circuitry, in the meantime I got a bunch of power supplies to build!!
Old 29th July 2008, 08:35 PM   #45
Why 33k, for what reason? The best way to ruin dynamics is by using series resistors. Make them as small as possible with stability in mind.
It is totally unnecessary with higher voltages as current is the weak point. Below 100V will be great! But as you say doubling up the tubes would be the way to go, more current...........
I dont envy you buliding this multi-tube amp. Looking forward to seeing (and hearing???) it when I pick up the horns.
Old 29th July 2008, 09:11 PM   #46
As I said, better safe than sorry. A friend ran some tests on an OTL circuit with 6 x PL36 some time ago and he needed gridstoppers in that range to stops the tubes from oscillating.
Tubes in parallel connection seem to require much higher values than single tubes.
More voltage would allow the tubes to deliver more current into a specific load, right? Tubelab mentioned something in the 400mA range for a single 6C19 with 75V plate-cathode, another member claimed 1,5A at 100-something volts in another thread long ago.
I also remember Bernt (at hififorum.nu) mentioning that one of his OTLs sounded much better after increasing the plate voltage from 150 to 170V (not sure about the numbers though).
However, Im going to use the transformers I already have and getting new ones would also force me to buy new PUS caps.
Ive built OTL amps before (one finished SE OTL and two unfinished PP monoblocks) and I can assure everyone that wiring all those tube tube sockets is extremely tedious.
The SE OTL used DC powered series connected P-style heaters which was a breeze to arrange compared to this.
Each bank (with four) output tubes draws 6,3V 4A AC supplied by one 50VA 2x6V toroid transformer per channel.
That means a lot of tightly twisted wire, Im glad Im finished with that part.
These amps will not be finished before I move (and hence before the horns must be picked up...) but Im not exactly lacking power amps to show you
Old 30th July 2008, 07:11 AM   #47
Dont think you should compare Berndts heavily NFBd and(almost?)Class-B amps with your Circlotron.
One should check the tube curves(which I havent done yet ) and choose the working poisnt where they are most linear. We must discuss this later!
Just for fun I will do a sim on the 33ks and see if it affects anything.
Old 30th July 2008, 01:27 PM   #48
I will start a thread about this project at hififorum.nu too so that we can continue this discussion in our own language
(By the way, is it ok if I use the spice schematic there too?)
Im not sure I want to know how much the 33k grodstoppers affects the HF...
Old 30th July 2008, 03:55 PM   #49
Yepp, move it! OK with the schematic, as it is to consider as a ruff sketch.
Old 31st July 2008, 02:53 AM   #50
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
An OTL amp is often best protected by 100K (value is not critial) or thereabout 1/2W gridstoppers.
These high values not only inhibit oscillations at RF frequencies but also isolate the grid from too high inrush currrents where the grid may tend to act as a fuse leaving you with a mighty diode iso of triode after the mishap.
Frank
6S19 Circlotron (OTL)Hide this!Advertise here!
Simple circlotron amp bigwill Tubes / Valves 4 18th March 2007 01:57 PM
Circlotron djk Pass Labs 13 20th August 2006 03:19 AM
6C33 Circlotron pat49hk Tubes / Valves 50 26th January 2006 09:06 AM
Supersymmetry Circlotron Circlomanen Pass Labs 6 18th April 2005 06:34 AM
Circlotron amps cuallito Tubes / Valves 7 25th April 2004 01:31 PM
