diyAudio Sponsor
Old 24th March 2008, 06:44 AM   #21
Miles Prower's Avatar
Default Re: Re: Re: A 6SN7 direct coupled preamp & regulated supply for everyone's perusal.
Originally posted by G
Hi Miles. Thank you very much for posting a reply. Here is the story about this circuit. I don't think I really need all that gain but maybe you can tell me after I tell you where I am coming from. I have been planning to build a matching (chassis wise) preamp and amplifier for a while. I actually decided on the amp first. It is a 12B4A gain stage and a 12B4A output stage.
If you don't need the gain, you can ditch some, and improve the linearity by doing a plate follower. First, get rid of the cathode bias resistor and replace it with a green LED. The Vf is quite close to the required grid bias, and the LED has very little AC resistance in the forward direction.
Next, apply the NFB to reduce the Avcl to about four (doesn't look like it'll need much more). If there's a problem of DC offsets from the source, you can add a DC blocking capacitor. For this, move the volume control to the output. The A Number One problem with this is that variations in source impedance, as you'd get with a volume control, will cause the closed loop gain to vary since that impedance is in series with Rs. Given an Avol= 15, make Rf= 5.1Rs. That should give Avcl= ~4.0. That should improve your THD to ~1.0%.
Plate Follower
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 24th March 2008, 06:56 AM   #22
G is offline G  United States
G's Avatar
Default Re: Re: Re: Re: A 6SN7 direct coupled preamp & regulated supply for everyone's perusal.
Plate Follower
How would this effect the output impedance?
Gavin
Old 24th March 2008, 06:16 PM   #23
Since this is a gNFB scheme, the NFB will reduce the Zo. Being a current feedback method, it will also reduce Zi. The latter isn't such a big deal since the open loop Zi can be made so high to begin with, way in excess of what you'd get with BJTs.
www.dolphin-hsl.com
capacitor coupled vs. direct coupled ouput hugobross Solid State 11 21st January 2011 01:56 AM
single endedtransformer coupled 6sn7 mic preamp gurpreet Tubes / Valves 3 15th February 2009 08:55 AM
6sn7 direct coupled and transformer coupled neazoi Tubes / Valves 3 23rd May 2008 03:30 PM
Regulated PowerSupply for Frank's 6SN7 Preamp Vidi Tubes / Valves 2 10th December 2006 12:23 AM
Can someone explain parafeed & direct coupled & a.c. coupled? mwmitchell Tubes / Valves 2 11th September 2002 01:10 PM
Page generated in 0.08084 seconds (77.95% PHP - 22.05% MySQL) with 11 queries
