Testing Amplifiers / Pad
Old 22nd March 2008, 12:04 AM   #1
Zap is offline Zap  United States
Default Testing Amplifiers / Pad
On a completely different note from my other post, does anyone here have experience with testing using Distortion Analyzers or Harmonic Analyzers? Specifically, I have access to some really nice equipment, but I would need to build a pad to convert from my standard output impedances to the 600 ohms that most test equipment uses as the input impedance. It would also have to attenuate significantly, if I understand correctly.
This is part of a senior project for school, and I haven't found any resources on this topic yet. Any advice is greatly appreciated.
Thanks!
Old 22nd March 2008, 01:20 AM   #2
HollowState is offline HollowState  United States
HollowState's Avatar
Hey Zap,
No distortion analyzer I've ever used required a 600 source for it's input. And I have used many different types including SoundTech 1700B, Amber 3501A & 5500, HP 334A, 8903A/B, Tek AA501, Boontons & my current favorite, the HP 339A shown below. But many sources do have a 600 ohm output impedance which has been the standard for many years to provide a level of compatibility between products.
Distortion analyzers have built in attenuators on the input for setting level. Some even have automatic level setting. You'd only need to attenuate if your source amplitude was past the range of the unit's maxium input. This is up to 300 volts RMS for the HP units.
Sooo....what analyzer have you acquired?
Victor
There cannot, and never will be, any progress in society, vis-a-vis racism, so long as the concept of celebrating Diversity -- in it's current, politically-correct, deliberate, punitively extractive form -- continues.
Old 22nd March 2008, 03:45 AM   #3
Poindexter is offline Poindexter  United States
Nice gear, Victor.
I hate you.
Testing Amplifiers / PadHide this!Advertise here!
Amplifiers, AB comparative testing, a blind test method. destroyer X Solid State 34 29th September 2009 12:39 PM
pro amplifiers vs. home audio amplifiers bonsai171 Solid State 26 25th February 2004 08:24 PM
Paradigm amplifiers? Anthem amplifiers? Corn-Picker Solid State 2 24th January 2004 03:10 AM
just testing Vinnie R. Everything Else 13 5th July 2003 12:59 PM
Many smaller amplifiers vs. bigger amplifiers. djdan Solid State 9 17th September 2002 04:40 PM
