Choke loaded PSU versus VR tube regulated PSU? - Page 4 - diyAudio
Old 20th March 2008, 04:58 AM   #31
zigzagflux's Avatar
Something like this.
Old 20th March 2008, 12:13 PM   #32
How do you calculate the resister after the IXYS CCS - in relation to the IXYS in terms of current or in relation to what the VR needs to see? Could you give an example to illustrate? Thanks!
Old 20th March 2008, 02:00 PM   #33
zigzagflux's Avatar
Not sure if I understand. Are you talking about the resistor in my latest schematic, tucked up against the source of the FET? This is chosen based on the total current I want to provide (23mA). I select it as an approximation based on the datasheet:
http://ixdev.ixys.com/DataSheet/98704.pdf
This gets you close, but you would really want to test for the optimal value.
There's a few threads on this and the DN2540 you could check out. They really do work well.
Old 20th March 2008, 03:45 PM   #34
G is offline G  United States
G's Avatar
Hi Zigzagflux. Check your email.
Gavin
Old 20th March 2008, 10:13 PM   #35
G's Avatar
Are you out there?
Gavin
Old 20th March 2008, 10:52 PM   #36
zigzagflux's Avatar
Sent you a reply email few hours ago...
Old 20th March 2008, 11:11 PM   #37
Hi Zig: I like the ixys current regulator plus vr tube voltage regulator approach for the PS. I am using it myself in a dht preamp that I'm working on. I also agree that given that setup, there is no longer a need for a choke in the PS. Keep up the good work!!
"Give me the Luxuries of life & I will gladly live without the Necessities" (Frank Lloyd Wright)
Old 20th March 2008, 11:45 PM   #38
G's Avatar
Oops. Forgot about THAT email address.
Gavin
Trouble choke loading tube in regulated supply phrarod Tubes / Valves 19 14th June 2009 07:13 PM
Choke loaded LTP jane Tubes / Valves 6 8th November 2008 03:25 PM
Choke Loaded ZenV8 RAM Pass Labs 2 30th September 2006 03:01 AM
How to design the straight load line for choke loaded tube ? Antonio Tucci Tubes / Valves 14 30th March 2005 11:05 AM
Choke Loaded Zen hacknet Pass Labs 17 8th April 2004 06:45 PM
Copyright 1999-2017 diyAudio
